Old 02-26-2021, 02:33 PM   #1
RupertPupkin
Drives: 2014 Camaro SS 1Le
Re-tune coming up
So I have my re-tune coming up on March 7th. I already have a flex tune etc etc etc. The shop said to bring in the car with e85 in the tank. From my understating, I thought I was suppose to bring in the car with 93, tune it, and then retune with e85.
Just trying to wrap my head around it.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 02-26-2021, 03:15 PM   #2
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
Do you know how they plan to tune the car? Some tuners will just tune for E85, and expect you to run E85. That just takes adjusting the main octane timing table and that's about it (along with fueling adjustments to run at the set lambda/afr). Then there's the true flex fuel tuning that has the tuner making the optimal 93 timing/fueling, then replacing the tank with E85. There is a separate flex fuel timing table (it's an adder adjustment table to/for the main timing table). And, a few other table that would need adjusting to ensure a true flex fuel tune, like in-between blends of 93/E85 (ratios). Might ask them their strategy. They might have assume the 93 tables are spot on and just need to do the flex fuel part of the tune.
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 02-26-2021, 10:42 PM   #3
RupertPupkin
From what they said they’re starting from the ground up. I just find it odd, that they would tell me to bring it in with as much e85 in it. Maybe work backwards. Idk.
730whp: 630Trq
Old 03-01-2021, 11:02 AM   #4
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Sounds odd. I was told to bring mine with 93 maybe an 1/8 of a tank and 10 gallons of E85 for after the 93 was done.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 03-01-2021, 12:09 PM   #5
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
This is what I would do ^^ just bring it in with less than a 1/4 and some gallons of E85 from the place you will be getting yours from and let them tune before driving it on E85
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 03-01-2021, 02:54 PM   #6
dreksnot
dreksnot's Avatar
Are you sure they're doing a flex fuel tune versus a dedicated E85 tune? FF tune would be running anything from 100% 93 to 85% E85, and every blended ratio in-between. A dedicated E85 would be just that - you can only run E85 (with the advanced timing setup).
Old 03-01-2021, 04:01 PM   #7
RupertPupkin
Yeah.... 100% Flex fuel tune. Just re-read my emails, unless im dyslexic.
730whp: 630Trq
Old 03-02-2021, 07:02 AM   #8
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
Yeah, under 1/4 tank of 93, then the ethanol tune. I could maybe understand their logic if you were just adding a flex fuel sensor to run E85. Use your existing tune for 93 and just tune for E85. Provided there were no other changes such as injectors. What's the reason for the re-tune? Just an issue with the ethonal tune? Since it can range from e51 to e85. I've always had the double tune. But other modifications were made. I would ask them why? Possibly a wrong statement in the email. Would sort of waste tune day.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 03-02-2021, 07:22 AM   #9
RupertPupkin
Starting from ground up. Tune was shit from the get go. Hot starts al the time regardless if I run 93/mix/ full e85. Also when I did wide open throttles, it would break up bad up top (not belt slip since I got new belt, and adjusted tensioner)
Specifically asked for a flex tune via email, so no confusion on that part.
730whp: 630Trq
Old 03-02-2021, 11:54 AM   #10
RupertPupkin
Got email back, and it is a flex tune. Shop did say to bring in the car with 93 and e85 in it during tune.
Still doesn’t sound right to me. Like drek said, it seems like it’s not getting the optimal timing table for 93 and e85.
730whp: 630Trq
Old 03-02-2021, 11:58 AM   #11
TheFlyingBananaSS
Not at all. So they want you to bring it in with both in the tank? How do they expect to dial in these parameters correctly? I dunno but their communication skills leave me scratching my head.
Old 03-02-2021, 12:11 PM   #12
RupertPupkin
Yup both in the tank when I drop it off. Here’s the response..
“That the beauty of flex fuel and it really does not matter the mix. Yes you would make the most power with 100% E85 but for tuning the car we can deal with a mix. If you desire true 93 vs E85 dyno graphs, then the car would need to arrive on 100% 93 to start. Then we would have to drain that out of the tank and put E85 in to make a final dyno run. There are associated labor charges for that process. It can be done but it only gets you numbers on a piece of paper. Just depends on how much that piece of paper is worth to you I guess.”
730whp: 630Trq
Old 03-02-2021, 12:15 PM   #13
TheFlyingBananaSS
So basically he's too lazy to do it the right way unless you pay extra? Tank doesn't not need to be drained either. As long as it's near empty, you can dump in 10 gallons of 85 and roll that for the tune. The top shops in the country do it this way.
Old 03-02-2021, 12:18 PM   #14
RupertPupkin
I was thinking of just rolling in with the 93, tune that, and then add in the flex fuel. I have 2 5 gallon canisters that I can put in e85.
730whp: 630Trq
