Old 02-28-2021, 07:22 PM   #1
Silver2014SS
Silver2014SS's Avatar
Drives: 2014 Chevrolet Camaro SS
Stock SS Pump with Aux Kit?
Anyone run a stock SS fuel pump with an SMG or DSX aux kit? I have a '14 SS w/ manual trans and boltons and I'm considering the ESS sc kit with a GPI cam. I'm estimating to be anywhere from 600 to 675 rwhp with the blower and cam. I'd be happy at that power level and could see maybe trying to push to 750ish in the future but that would be the max I'd be comfortable with on the stock block before going forged.
I'm kind of stuck with fuel. Not really a fan of the idea of doing all the work to swap in a ZL1 pump just to have it on the brink of being maxed out, and not really a fan of going all out and dropping major coin on a Fore or Squash kit which I think would be way overkill. Doesn't seem like there's many fueling options between the ZL1 and Fore/Squash.
Seems like there are a lot of guys with the ZL1 pump + aux kit with over 1k wheel hp, so if an SS pump + aux would cover 650 up to 750-800 that would be the sweet spot for me.
Forgive me if this has been answered but I've been searching and emailing people for the last couple months and haven't found an answer to this specific question.
Silver2014SS is offline   Reply With Quote
Old 02-28-2021, 07:35 PM   #2
Vegas Bound
Drives: 2013 Sparkly Red One
Pump gas may be ok but not e85.
Vegas Bound is offline   Reply With Quote
Old 02-28-2021, 10:10 PM   #3
RupertPupkin
Drives: 2014 Camaro SS 1Le
I haven’t seen nor read a 1000whp camaro using ZL1 pump/aux kit. Unless I’m not looking, but I did the same song and dance b4.
Do it right the first time.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 03-01-2021, 06:30 AM   #4
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
There isn't anything between a ZL1 pump with an auxiliary and a full system. I have been going back and forth with figuring out what I want to do. I even bought a new aftermarket CTS-V pump with the thought of using it as is or upgrading the pumps. There are a couple of companies supposedly working on drop ins but development seems slow and I'm losing faith as our cars get older.
Old 03-01-2021, 10:56 AM   #5
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
I've got the ZL1 pump and putting in the aux this week. Don't forget about your injectors.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 03-01-2021, 11:59 AM   #6
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
I know its dumb for me to be complaining about costs, especially after all the money I've already spent, but I cant say anything bad about someone trying to find a cheaper way to fuel these cars. Paying $2500-3000 just for a fuel system, minus the injectors mind you, sucks in a way I cant put into words here lol
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
gunchamp is offline   Reply With Quote
Old 03-01-2021, 12:06 PM   #7
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
I agree it’s a lot to spend on just fuel alone. But without that fuel you can’t have the power. Wish there was a cheap way to do it so you can spend the money and other go faster parts.
http://rpmspeed.com/product_info.php...umsel4hsjirg62
Stealth pump supports over 1k hp but haven’t heard anyone using it
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 03-01-2021, 02:06 PM   #8
RupertPupkin
https://www.camaro5.com/forums/showt...ighlight=A1000
730whp: 630Trq
Old 03-01-2021, 05:30 PM   #9
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
Check out AGP Turbo. A few years ago, I bought their twin pump setup and flex fuel kit for $1800. Probably the cheapest way to get a fuel system that will support 1000rwhp.
-Scott
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 03-01-2021, 06:19 PM   #10
TheFlyingBananaSS
I see ZL1 pump and DSX aux pump support well over 800whp all the time. And it's still cheaper than a dual or triple pump. Plan on spending at least 2k if you go dual or triple once your done with fittings and lines. I priced up the aeroforce stealth for mine and it was over 2k. Meanwhile the aux pump will be fine for my needs and still leave me a bit of growth room.
Old 03-01-2021, 07:47 PM   #11
Bigdumogre
Bigdumogre's Avatar
Originally Posted by RupertPupkin View Post
That’s brutal ouch. No wonder you don’t hear about them
Old 03-01-2021, 08:39 PM   #12
Silver14
Drives: 2014 SIM 2SS
-Scott
I have their twin pump, running 93, 850cc injectors and still have a ton of room to grow. Made a little over 600rwhp, 7.5 psi, max 55% duty cycle. Comes with everything to install, no additional parts needed.
Fuel system is one of those "buy once, cry once" things.
Silver14 is offline   Reply With Quote
Old 03-01-2021, 08:43 PM   #13
Silver2014SS
Appreciate any and all feedback. Maybe I misread what I thought was 1k hp Camaros with ZL1 + aux. I've been doing so much searching and reading my brain is a bit fried.
Old 03-01-2021, 09:02 PM   #14
RupertPupkin
Get the ZL1 pump, DSX aux pump and call it a day. If you need to drop in a dual or triple pump in the future, you can flip the DSX & ZL1 pump later down the road.
https://www.camaro5.com/forums/showthread.php?t=588712
ZL1 pump 100$
730whp: 630Trq
