Old 02-28-2021, 11:40 PM   #1
IKILLEDSUPERMAN_ZL1
Drives: 2011 Camaro SS
My turbo install- it finally runs.
It's been awhile but the car is running. It still needs a tune which I'll get this coming week. I took a short video. Sorry but it was windy AF today. Recap of mods. It's a L99 with a Huron speed single turbo kit. VSracing 7875 gen1, Summit stage 2 turbo cam with the supporting BTR valvetrain for the LS3 conversion. Exhaust is the 3 inch DP to unk brand X pipe with no resonators or mufflers from previous muffler delete. I did the rear suspension with BMR parts, cradle bushings and ZL1 pump and BAP before the turbo. So far all sounds good and no issues. I'm excited to get it tuned and drive it. I havent driven this car since early last summer when all the install was started!
https://youtu.be/jE2MN9r7PiU
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
IKILLEDSUPERMAN_ZL1 is offline   Reply With Quote
Old 03-01-2021, 02:15 AM   #2
InFiD3ViL
InFiD3ViL's Avatar
Oh man, she's gonna be a beast! My god, I couldn't imagine having a big spinnyboy bolted to my 6.2
Just curious, have the rings already been gapped a bit more or are you just going to keep the boost at a safer low level? What are your power goals with this setup?
Old 03-01-2021, 06:11 AM   #3
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Looking good. Should get some nice numbers from the dyno.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 03-01-2021, 10:20 AM   #4
IKILLEDSUPERMAN_ZL1
Stock bottom end. My goal is mid 650 rwhp. It put down 360 before the mods. So I am hoping to add 300 hp and be around 650 ish with the cam and 12 lbs of boost.
Old 03-01-2021, 11:09 AM   #5
gsxrturbo
Drives: 2010 ss
pretty sure you will run out of fuel after 600whp.with the zl1 pump and bap and dont for get about injectors
gsxrturbo is offline   Reply With Quote
Old 03-01-2021, 11:12 AM   #6
FrankT
400HP used to be enough..
FrankT's Avatar
Drives: 2010 2SS rs manual
Glad to see you finally got it running. You'll probably be happy at nine or ten pounds boost. I think it would be more streetable at that level.
FrankT is offline   Reply With Quote
Old 03-01-2021, 11:29 AM   #7
11-Camaro
Drives: 11 Camaro SS, Ninja 1000, Santa Fe
Keep us posted on the tune. Love to see the build sheet and net whp.
11 Camaro TT SS. 14 1LE motor, full coilover, CNC ported LSA heads, stainless valves, dual springs, Comp 224 cam, Melling oil pump, AGP Garrett GTX30r's, 1400cc injectors, full 3" Magnaflow, dual Walbro 450lph fuel pump, ZL1 6L90 trans, trans cooler, Circle-D 3600, 3.91:1 Eaton Truetrac, line lock, Lingenfelter 2 step. Current boost - e85 814 RWHP.
11-Camaro is offline   Reply With Quote
Old 03-01-2021, 11:47 AM   #8
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
Sounds badass! Shes gonna be a beast
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
gunchamp is offline   Reply With Quote
Old 03-01-2021, 11:48 AM   #9
gunchamp
gunchamp's Avatar
If on 93, I think you can go a bit past that with a 1050 injector. Could be wrong though
Old 03-01-2021, 12:12 PM   #10
IKILLEDSUPERMAN_ZL1
I'm using 1000 cc FIC injectors and on 91 octane. I'll prob throw the SMG aux pump on there to be safe.
Old 03-01-2021, 12:16 PM   #11
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Sounds great man!! She's gonna be a beast for sure!! Good luck and let us now how it goes. Like InFiD3ViL said, I too couldn't imagine a turbo of SC setup on MY beast, it would be awesome no doubt!! Enjoy.
Old 03-01-2021, 02:11 PM   #12
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
over 700WHP here on 12psi ZL1 pump with FPCM no fuel pressure drop.
Greenhornet2 is offline   Reply With Quote
Old 03-01-2021, 06:25 PM   #13
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
I’m a manual and at 8 lbs of boost, 650rwhp , 1000cc injectors, running ZL1 pump and a JMS booster. No fuel pressure issues and injectors are at 60% duty cycle. With an auto you may be pushing it it should be do able.
HOJO is offline   Reply With Quote
Old 03-01-2021, 08:40 PM   #14
wasthatacop?
wasthatacop?'s Avatar
Drives: 2010 2SS
I'm so jealous
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts,
1.4" BMR lowering springs
ZL1 factory rims
misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete
wasthatacop? is offline   Reply With Quote
