Old 03-03-2021, 04:48 PM   #1
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
Boost level quention
So, how much boost would you guys feel is safe running in these motors with 93 octane only? LS3, L99 motors in particular. E85 was everywhere here, but a couple stations have stopped carrying it, so worried its gonna eventually dry up. I know even low boost can kill a motor, so I understand no guarantees here. Will be remotely tuning with Ted Jannetty when I do this. My compression is a bit higher than stock mind you, with the GPI max kit. I believe its close to 11-1. I'm thinking with a good tune, I could run 10 psi max. Thoughts?
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
gunchamp is offline   Reply With Quote
Old 03-03-2021, 04:56 PM   #2
Silver14
Drives: 2014 SIM 2SS
I think a better approach is targeting a power level instead of boost. If I recall correctly, Ted has posted that 650ish is as far as he likes to take the stock bottom end.
Lots of others going way past that though
Silver14 is offline   Reply With Quote
Old 03-03-2021, 05:45 PM   #3
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
With the GPI Max, you aren't going to need as much boost because of how well everything flows. That said, the extra compression gives you less room for error.
Old 03-03-2021, 05:54 PM   #4
RupertPupkin
Drives: 2014 Camaro SS 1Le
If you have a spot on tune, I would personally send it. Fortune favors the bold I always say.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 03-03-2021, 06:18 PM   #5
Warship2k15
Drives: 2010 Camaro 2SS
Ok boost is the restriction to flow.A stock Camaro with stock cam and heads might have more boost from a certain supercharger then a modified motor with better flowing heads and a bigger cam.
But which one do you think will make the most power??
So you really can’t go by boost unless everything is the same.
Now ted or someone else who has worked on or had a similar setup might be able to give you a close number.
Warship2k15 is offline   Reply With Quote
Old 03-03-2021, 07:11 PM   #6
gunchamp
gunchamp's Avatar
You guys are right. So im after the 650-700whp. Thats probably a better question
Old 03-03-2021, 07:11 PM   #7
eLeSthree
Drives: 2011 Camaro SS 6sp
With a higher flowing, higher compression setup, id agree. 10psi is good max level. It should make more power per psi than other setups. You should be happy with it. Why over do it? Ted will get it right.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 03-04-2021, 07:46 AM   #8
gunchamp
gunchamp's Avatar
Thank you sir and yes, I feel very confident with Ted moving forward
Old 03-04-2021, 08:10 AM   #9
Silver14
What method of boost are you considering? Looks like a potent combo already
Old 03-04-2021, 10:07 AM   #10
gunchamp
gunchamp's Avatar
Centri. Spoke to Ryan at GPI and he said the max cam will work great with a centri. So probably an ESS system
Old 03-05-2021, 07:29 AM   #11
RupertPupkin
Can never go wrong when you add any power adder, especially FI. Boost juice is addicting
730whp: 630Trq
Old 03-05-2021, 07:46 AM   #12
gunchamp
gunchamp's Avatar
Very true. I built a blown 4th gen some time back and it wasnt long I was pushing the limits lol. Boost is fun for sure
Old 03-05-2021, 08:31 AM   #13
Silver14
That should be very impressive, thinking about the standard blower they sell with their kit or upgrading to a larger one
Old 03-05-2021, 08:54 AM   #14
gunchamp
gunchamp's Avatar
I'm thinking of going larger. G3x most likely. Still in the researching stage. My car wont be out on the road until mid-April at best. We got pounded with snow this year and the roads are a mess with cinders. So I have some time yet. Got to do the fuel system as well, cringing on that one lol
