Old 03-05-2021, 09:26 PM   #1
Alpha11
Drives: 2012 Camaro SS
Question Odd Voltage Readings Leading to Lean Codes!
Hello everyone,
I have a lean condition code at this time and after logging o2 voltages I noticed values constantly jumping from 0 to .58 My O2's (yes each o2 up and down stream and both banks) are typically reading 0-.15 v which does not seem right I believe they should be hovering around .45v. I was using torqueApp. Has anyone monitored O2 voltages on torqueapp on their car? Can you share what you received?
I can share the CSV if needed but fuel trims stay around 0 after starting and warming up and the voltage is totally sporadic so it does not follow any inputs really
Alpha11 is offline   Reply With Quote
o2 sensor, o2 voltage, oxygen sensor voltage, voltage
