![]() Drives: 2013 Camaro SS 2SS Join Date: Apr 2019
Hey peeps i have heard of some people swapping the stock pump to the CTS-V pump, i have a 2013 SS L99 with a procharger and my pump is starting to be iffy just wondering what year or model of cts-v pump i should look for?
any help would be great, Cheers |
![]() ![]() Drives: 2014 1SS/1LE Join Date: Nov 2015
I bought a new aftermarket CTS-V fuel pump but not sure if I'm going to use it.
#4 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
Some of the early twin pump kits that came out where just that; CTSV pumps and reflashed truck FPCM. My car has had the Lingenfelter version for 165k miles or so. I've replaced the pump once about a year ago only because the fuel line connection cracked.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
#6 |
Yeah that’s ultimately what I’m looking for is the dual pump but I’m just not 100% sure why years those were offered or what model number that was.
#7 | |
http://www.rockauto.com/?carcode=3308741&parttype=10147 Sent from my Pixel 5 using Tapatalk
#8 |
But correct me if I’m wrong it’s not just a drop in and go kinda thing isn’t it set up for a return style system??
Orange Krush II
#9 | |
In my case, I would also need larger drop-in pumps and likely a vaporworx control unit.
#10 |
![]() ![]() Drives: 2014 SIM 2SS Join Date: Sep 2015
Good deal here:
https://www.camaro5.com/forums/showthread.php?t=589191 |
#11 |
Somebody needs to jump on that deal.
