Coilover question... Pedders
I was looking at buying PEDDERS XA COILOVER KIT. I haven’t seen a whole lot on the install. My question is will I have to drill a hole in the truck for them? I read where if you install the BC coilovers you have to drill a hole in the trunk to get to the adjustment knob.
No, no drilling hole in trunk. To adjust the rears you need to lay on your back behind the rear wheels and reach up to the top of the strut where the upper spring mount is to turn the knob for adjustments. You do have to drill a small hole in the upper spring mount which bolts to the body so a short piece of cable attached to the shock adjuster with a knob on the end which is your rear shock adjuster. The instructions show exactly where (via measurements) the hole is drilled in the upper shock mount so the cable can pass thru. My XA's have been installed at least 6 or 7 years I believe, no issues.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter, SS brake lines ZLI calipers, rotors/pads BMR Trailing & Toe Arms, rear cradle/diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers, HF cats, GMPP axle back, Elite Eng Catch Can, Black ZL1 20x10 & 2011 whls 285/35/20 & 305/35/20 General G-Max RS, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console, hand brake lever, Grant steering whl.
#3 | |
![]() Drives: '15 Silverado LTZ & '13 ZL1 ragtop Join Date: Nov 2016
The Strange coilovers have the adjustment knobs at the bottom. No drilling at all. Those are the ones that come with the BMR drag suspension. Very easy to reach and adjust with just a floor jack.
HP tune, Kooks 1 7/8" LT w/ cat deletes, FIC 1300 inj, E85, GPI SS3 blower cam, Fore Innovations Gen 5 dual pump module with twin TI Automotive 430 lph E85 compatible pumps, Lingenfelter 10 bolt 2.55" upper/9.17" lower pulleys, AFCO triple pass intercooler with dual fans, Killer Chiller interchiller, B3R insulated expansion tank, full BMR rear drag cradle and suspension, DSS one piece driveshaft and Stage 5 billet axle shafts, Rotofab CAI, reinforced brick, Devil's Own progressive methanol injection, FTI 9.5" billet lock up Street Racer torque converter, 3200 rpm stall, triple clutch.
![]() ![]() ![]() ![]() Drives: 2013 1SS 1LE Join Date: Jun 2016
I have Pedders coil overs. The rears have a cable extension that comes with the kit so you don't have to drill holes. They are very nice imo. I've been on them for almost 3 years now.
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
#6 |
Just like he said, when you take everything apart you'll need to drill holes in the upper shock mount. It's hard to adjust without having the car up.
If you have an older car, look into which version of the shock mount you have. The 1LE cars got a redesigned version and then later they put it on other cars. How you mount up the shock mount to the pedders coil over changes depending on which type you have - that goes for the front and rear if I remember right. Sent from my Pixel 4 XL using Tapatalk
