Old 03-12-2021, 11:42 AM   #1
Philipz3
USM1LED
Drives: Chevrolet Camaro
Exclamation Searching for Rear Axels
So a few weeks ago I started having an obnoxious chirp or squeak that sounded like it was coming from the clutch, rear wheels, or breaks. I was getting a "chirp" every time the clutch engaged whether I was moving from a stop or shifting while already moving.
After going to 2 shops we diagnosed the issue as being the axels have slight movement causing the squeak. The car was on coils for about 2 years and has been on air ride for about a year now. From what I understand having a low Camaro really strains these axels.
Now the issue I'm having with a 2015 SS 1LE is that my axels are different from the standard SS. I believe they match a ZL1s axels. I've spent the last few hours doing research and it seems they have been discontinued and no one in the country has them. This would be part numbers 22806795 for the left rear axel and 22806796 for the right axel. These part numbers I received from a GM dealership after giving them my VIN and was told they are standard SS axel part numbers from Phastek when I told them. So, my next solution was do pickup some from Acdelco. It turns out they have also discontinued their replacement axels.
At this point, it seems my only option is to upgrade to after market axels from GForce that cost around $1500 and take 10 - 12 weeks to get here or from Driveshaft Shop for $1200.
I just ordered the axels from Driveshaft shop and hopefully they will align with the car. If anyone could double check that what I ordered will fit or that the information i've gathered is write or wrong that would be great. This has been an all day project with little success.
Also If anyone themselves has replacement axels for sale please message me. Thanks everyone.
USM1LED
Philipz3 is offline   Reply With Quote
Old 03-13-2021, 12:15 AM   #2
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
The axles having a slight amount of play is normal. Axles usually do not chirp, they making a clicking noise when the thrust washers go bad. Are you sure you don't have a bad pilot bearing or throw out bearing? Since you said the noise is related to you operating the clutch.
More to come.
Black_SS10 is offline   Reply With Quote
Old 03-13-2021, 01:28 PM   #3
gsxrturbo
Drives: 2010 ss
I WILL have a pair of gforce 1000hp axles with about 2000 miles on them for sale this spring.waiting on a custom driveshaft. doing a zl1 3.73 diff swap.I will have a 1Le diff for sale with 6 to 7 thousand miles on it.Also has a lpw cover on the diff.The parts are on the car.and the car doesnt come out till spring...curt 507-351-2727 if any questions
gsxrturbo is offline   Reply With Quote
Old 03-13-2021, 06:48 PM   #4
gsxrturbo
Drives: 2010 ss
OK it was nice out today. removed my diff and axles,i dont know how to post pics here.text me at 507-351-2727 for pics.would like 1200 for the axles and 1200 for the diff. plus the ride or you can call me...curt
Old 03-14-2021, 07:56 PM   #5
Rem0v3r
Drives: 2013 ss2 vert l99
Swap the the zl1 rear end and use stock zl1 axels.. the ss rear is made of chocolate.
Rem0v3r is offline   Reply With Quote
Old 03-15-2021, 04:36 AM   #6
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
The SS Diff is better than you think, the Z28 uses the SS case.
Orange Krush II
Old 03-15-2021, 10:03 AM   #7
Vegas Bound
Drives: 2013 Sparkly Red One
I have a set of SS axles in my garage with less than 5000 miles on them.
Vegas Bound is offline   Reply With Quote
Old 05-12-2021, 11:16 PM   #8
shnormo
Drives: 2010 1SS Camaro
Well I finally broke an axle on the passenger side. Anyone still have either an OEM or an aftermarket upgrade for sale?
shnormo is offline   Reply With Quote
Old 05-13-2021, 03:03 AM   #9
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
I have a pair of oem axles and I'm not far from you. Sae shipping costs
ttshovel is offline   Reply With Quote
1le, 2015, parts, rear axel, replacement
