03-13-2021, 07:11 PM | #1 |
Drives: 2012 camaro 2ss rs L99 Join Date: Feb 2017
Before and after or current
Let's see the before and after or current state of your engine bay.
Here is mine, the top picture is from this morning and the bottom 1 was in 2018 (after some mods lol) but it's a crazy contrast I think lol Let's see yours.
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
03-13-2021, 08:17 PM | #2 |
Drives: 2015 2SS Commemorative Edition Join Date: Mar 2020
03-14-2021, 12:46 AM | #3 |
03-14-2021, 06:31 AM | #4 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
Before my build and current.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
03-14-2021, 08:59 AM | #5 |
Before first one and after, second one!!
03-14-2021, 09:40 AM | #6 |
Drives: 2014 Camaro LT Join Date: May 2020
Today
Took this this morning
03-14-2021, 11:53 AM | #7 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Haven’t hosed it down in a while but it’s getting better.
03-14-2021, 12:21 PM | #8 |
Here is mine before
This morning
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
03-14-2021, 12:27 PM | #9 |
CamaroFans.com
My old Pace Car...
03-14-2021, 01:01 PM | #10 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Coil Mounts
How hard is it to mount the coils like that and where did you get the coil harness extension?
Orange Krush II
03-15-2021, 06:58 AM | #11 | |
I made the coil mounts in both pictures and extending them to work with the second setup is simple, just extended each wire. The coil mounts in the second picture bolt on to the valve covers in the mounting holes. I made the wires with parts from summit.
03-19-2021, 03:17 PM | #12 |
Drives: 2014 SS 1LE Join Date: Jun 2016
how are you guys keeping the engine bay so clean?
Or maybe a better question is what are you using to clean them?
2014 1LE
cold air inductions kooks BTR stage 4 UDP GPI ported Tb & manifold 491whp pump 510whp E85 715 whp RCSB silverado for the straight line stuff |
03-19-2021, 03:42 PM | #13 |
lol, on mine it is a daily wipe down after a cruise. I use my waterless spray wash and then go over everything with my spray detailer. Don't do it while the engine is still warm though, let it cool down a lot before or it might leave streaks from drying too fast. I spray the micro fiber with the solution, not directly on the parts, works better that way.. It's time consuming, but hey it looks great when you are done. Been doing it for 10 years on her.
03-19-2021, 04:32 PM | #14 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
