![]() ![]() ![]() ![]() ![]() Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
Cold start- is this normal
Had a tune redone, and everything runs great. However, when I start the car when cold, the RPMs start at 1200. After a minute or 2, it settles to 900.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Yes
Hmmm. Weird. My g8, nor my c6z never did that, where it’ll idle higher for a couple of minutes then settle down.
Yep, normal.
Tuned by Ben @BWTuned, GPI 416 w/GPI S/C Cam, GPI Ported Heads, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump/DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Rossler T400 w/t-brake, Circle D Converter, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.73 Diff, DSS Axles, Wiles Racing Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
Hmmm.
1 yes 1 yep and 1 weird. |
#6 |
Yep, mark me for "normal". lol. Mine does that.
#7 |
It don’t come easy.
Add me to the “yep” list.
#8 |
![]() ![]() Drives: 2014 1SS/1LE Join Date: Nov 2015
Yep
#9 |
The ayes have it
#10 |
Thank you
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
Normal
#12 |
Well, it's normal if your tuner set it up for that RPM when the coolant temp is at whatever. This can be changed if you dont like it. It's quite flexible.
#13 |
![]() ![]() ![]() ![]() Drives: 2012 Camaro SS Join Date: Dec 2019
Cammed cars idle around 1000 rpm depending on the cam and the tuner. All my cars I ever owned started high and drop rpm once they are warmed up.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
#14 |
My car on a freezing day will start at 1100 rpm and idle down to 750 in a minute or so.
