Old 03-17-2021, 02:25 AM   #1
gen=5
gen=5's Avatar
Drives: 13 ZL1 vert blac fastlane/LPE 750
Ok not wanting someone to think I’m Ruining a marketplace ad I’ll ask questions here
Ok..it’s a 2010 with about 50k blown, with about 1000,hp crank ..
If it’s running 15-16 psi on cast pistons how long will it last!? ...
I’m running 20psi on my truck,twins but it came with turbos ,and it’s not pushing almost 3 times the stock power output..of a factory NA motor..
Granted (subject motor) it’s on e85 and able to run 93 as well, which 93 is what id probably run most of the time given how e85 seems to be all over the place with its octane rating....
I’m not wanting a car which might expire Due to cast pistons or and the wrong ring gap from the factory ...
If it had gapless rings on cast pistons at least I’d feel better ..but the only blown LS motor I’ve pushed is my ZL1 and a purpose built forge motor..
Anyway opinions, on a stock block with high miles as 50k on 1000hp I’d consider high miles ..thks.
http://www.camaro5.com/forums/showthread.php?t=346589 CHECK OUT THE BUILDING OF MY RANCH FOR DISABLED VETS, COMPLETE WITH A GUN RANGE .
gen=5 is offline   Reply With Quote
Old 03-17-2021, 10:28 AM   #2
Pearlj10
Drives: 2011 Camaro 2LT
It looks like you inadvertently posted in the V6 FI section.
Pearlj10 is offline   Reply With Quote
