Old 03-17-2021, 05:11 PM   #1
Pearlj10
Drives: 2011 Camaro 2LT
High Pressure Fuel Pump
Has anyone successfully run a LFX HPFP on the LLT? I remember a vague reference that someone did it but it required bending one of the hard fuel lines. I’m not trying to go crazy and run a LF3/4 pump with a Ferrari lash or anything, just wondering if the better flowing LFX pump could be a legit option for more fuel under boost.
Thanks
Pearlj10 is offline   Reply With Quote
Old 03-23-2021, 06:35 AM   #2
KillboyPowerhead
Drives: 2015 Z/22
You could reach out to Overkill Will who might have some experience with this.
KillboyPowerhead is offline   Reply With Quote
Old 03-23-2021, 10:00 AM   #3
Pearlj10
No doubt. Will did reply with this helpful info:
At the moment there's no HPFP for the LLTs. The LFX/LF3/LF4 pumps are incompatible electronically, they're Hitachi while the LLT is a Bosch unit.
fuel pump, hpfp, llt engine
