![]() ![]() Drives: 2014 1SS/1LE Join Date: Nov 2015
Turbo cam, pushrods, crank pin kit
Forgot I still have this stuff...
Leftover new parts from an LS3 build that changed direction. Prices do not include shipping. Prefer PayPal. - GPI Custom Twin Turbo Camshaft (106172, XA230-370, 236-370-117+4), Test Fit Only, $300 - BTR Chromoly One Piece Pushrods 7.950" Long, 3/8" Diameter, .080" Wall, Test Fit Only, $80 - LS Crank Pin Kit (Includes New GM 12557840 Crank Bolt), New, $50 ![]() ![]() ![]() ![]() ![]() Sent from my Pixel 5 using Tapatalk
![]() Drives: 2010 Camaro SS Join Date: May 2019
What was the camshaft spec'd for? CI? RPM range? Compression? Turbo size? Power level desired?
