![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Center brace bolt hole is gacked
This might seem like an odd question but does anyone know how to replace the threaded blocks or pieces for the tunnel center brace? One of mine has gotten messed up and wont let the bolt go all the way in. Tried finding parts on a few GM sites and haven’t found anything.
Short of ramming the bolt in there does anyone have a suggestion?? Would like to put the brace back in if I can
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 SS 2SS M6 Join Date: Aug 2016
you could try running a tap thru it...do you know how it got damaged?
Good luck! PEACE
#3 | |
Thinking about using a bigger rivnut but not sure what the diameter of the hole is. Will be checking it out later tonight
2010 2SS/RS
