Old 03-21-2021, 12:09 AM   #1
rober
Drives: 2015 camaro
Raise seat higher for more visibility
I want to raise both the driver and passenger seats on my 2015 camaro. Has anyone done it before? If so, could you show me how to do it? Thanks!
rober is offline   Reply With Quote
Old 03-21-2021, 12:29 AM   #2
BuddyLee
BuddyLee's Avatar
Drives: 2013 Camaro 2SS/RS
You have power seats? I can elevate mine until my head touches the headliner. Lift up on the seat control on the left of your driver seat or right one the passenger side.
BuddyLee is offline   Reply With Quote
Old 03-21-2021, 12:54 AM   #3
Tarendor
Tarendor's Avatar
Drives: 2012 camaro 2ss rs L99
Washers as spacers.
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
Tarendor is offline   Reply With Quote
raised seat, seat, seat heater, seat help
