Old 03-21-2021, 07:26 AM   #1
V1SIOUS5THGEN
Drives: 2015 Camaro SS
Misfire readings on cylinder 8
So I’m picking up misfire readings on cylinder 8 watching misfire counter on snap-on scanner. I’ve swapped coil and wire to different cylinder but still showing misfire. Pulled old plug and it was black on tip. Added new colder plug and week later it’s black as well. What could be the issue? I have bigger injectors and Ecs supercharger plus cam
V1SIOUS5THGEN is offline   Reply With Quote
Old 03-21-2021, 08:04 AM   #2
sdynak
Drives: 2014 ZL1
Would think injector based on what you did so far. Likely leaking. Might see in a pressure test (pressure dropping gradual after pump prime). A compression test would not hurt either.
2014 ZL1 Black All OEM, Manual
SOLD: 2010 1SS LS3, Black, 235/250, .621/.615, 114 + 4, Kooks Stepped Headers, 3.91's, Bo White PTB, Flowmaster Mufflers, Cold Air Industries CAI, Apex Scoop & Windshield Washer Relocate, SLP Wheels, Skip Shift Eliminate, Barton Flat Stick, OEM HID/Halos, Dyno Tuned by ECS
sdynak is offline   Reply With Quote
Old 03-21-2021, 08:48 AM   #3
V1SIOUS5THGEN
Ok. Would you recommend i swap injector to different cylinder first or compression test? Which is quicker?
Old 03-21-2021, 09:43 AM   #4
V1SIOUS5THGEN
Not sure if your tagged when i hit quote on reply
Old 03-21-2021, 03:21 PM   #5
V1SIOUS5THGEN
Can anyone else chime in on this question please
Old 03-21-2021, 03:57 PM   #6
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
check for a cracked plug. some are hard to see. but will cause a misfire, happened to me on the dyno.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is online now   Reply With Quote
Old 03-21-2021, 04:12 PM   #7
V1SIOUS5THGEN
So this occurred with old plugs in it and then i changed to a colder plug and it still shows a misfire on cylinder 8. I pulled that plug as well a week later and it was black as well on the tip. Everything I’m reading leads up to a possible injector leaking but not sure.
Old 03-21-2021, 04:16 PM   #8
tartagliazl1
swap the injector to the #1 cylinder and see if it does the same thing to the #1 plug
Old 03-21-2021, 05:15 PM   #9
V1SIOUS5THGEN
I’m gonna do that but didn’t realize how big of a job it is lol. Do you think that would be the only issue or do a compression test on that cylinder as well?
Old 03-22-2021, 12:13 PM   #10
silversleeper
Big Crow
silversleeper's Avatar
Drives: '13 ZL1
Needs a rebuild. There is a chance that hard to get to plug got cracked, start with putting in a new plug before pulling the engine for a rebuild. And black on the plugs might want a hotter plug not colder, but that won't fix it here.
silversleeper is offline   Reply With Quote
Old 03-22-2021, 12:58 PM   #11
RankSS
Drives: 2010 Camaro SS
Could be a valve spring or ring land.
First step would be a compression test. Then if ok remove the valve cover.
Swapping injectors is not a huge job but I doubt this is the problem.
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
RankSS is offline   Reply With Quote
Old 03-22-2021, 03:22 PM   #12
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
swap the coil, and plug wire to a difference cylinder to see if the misfire moves. compression test is quick and easy. test all of the cylinders on that bank it will tell you what normal compression should be. Injector swap would be the last thing I do if all else checks ok. If compression is low pull the valve cover look for broken spring or loose rockers missing trunnion needles.
Greenhornet2 is offline   Reply With Quote
Old 03-22-2021, 05:22 PM   #13
V1SIOUS5THGEN
I’ve done swapped coil and wire and it still showed a misfire on 8. Will do compression test next. Would i not hear a ticking if rocker or spring was loose?
Old 03-25-2021, 05:56 AM   #14
V1SIOUS5THGEN
So we’ve done compression test and number 8 is about 20 down from the rest of cylinders. Readings were in the 180s on all but cylinder 8 which read in the 160s. They did a blow by and it came back perfect. Spring and lifter look fine as well. They also swapped injectors but misfire counter still shows misfire on 8 ����*♂️ Anything else y’all can recommend checking?
cam, cylinder 8, ecs supercharger, misfire
