![]() Drives: 2013 ZL1 Join Date: Mar 2021
For everyone is lookig to change to coil-overs or Air from Mag Ride, this is for you!
A few years back I changed over from my Mag Ride struts to a full Airlift 3P kit. In doing so I needed to fool the car to think that the Mag Ride struts were still there and the ones you can buy online are $300-$500 and I figured there had to be a better way. So I did some research and for $50-$75 I made my own and have been running them for 3.5 years with no issues. All info needed to make them as well as links to buy everything is included in the PDF document. If you need any assistance shoot me a message on here or my other contact info is in the PDF -Brandon |
Why 24” of wire? Could you make them shorter?
Orange Krush II
You can make them however long you'd like. The rear I mounted tucked up away from the elements so it needed a bit more wire. The fronts were close to the strut and could have probably been 12"or less. Either way length doesn't matter it's just the amount I used
Front Mounting location. I don't have a picture of the mounting location in the rear on hand.
I thought maybe it had to do with the wires length and resistance or something.
Orange Krush II
#6 |
![]() Drives: 2012 ZL1 Camaro Join Date: Dec 2015
thanks for this. This will help me greatly!
~01 zO6~ (Procharged/bolt-ons) SOLD
~05 Vette~ (Procharged/Bolt-ons) SOLD ~98 Z28~ (TMS 408/RPM LVL 6/Circle D4k) SOLD. ~00 SS~ (Forged LS/IIHS 7875 Turbo/RPM Lvl 6/Strange S60) 10.3-141 ~2010 SS~ (SLP TVS2300 Blower/Speed Eng LT's) ~2012 ZL1~ (IIHS Twin Turbo) |
#7 |
No problem, Here is an updated link to other resistors that will also work since the ones listed in the PDF seem to be out of stock.
https://www.mouser.com/ProductDetail...08%2FBZESZM%3D |
#8 | |
#9 |
![]() Drives: 2012 ZL1 #1156, 2003 Silverado SS Join Date: Feb 2018
I see you have a 2013 ZL1. Does this work for the 2012?
2012 ZL1 #1156, born 5/8/2012. Rotofab cold air intake, Elite Engineering catch can, Texas Speed Long tube headers with off road connections and of course a tune by DynoSteve.
#10 |
![]() ![]() ![]() ![]() ![]() Drives: Never just fly under the radar Join Date: Jul 2015
I'm obviously not the OP but it should work. I've never had a reason to do it but it's pretty universal lots of people do it on Tahoes and such. Would just maybe Google mag ride delete how to.
Old Skool |
| Tags |
| coilover, diy, magride, struts |
