03-23-2021, 02:25 PM | #1 |
Drives: 2014 Camaro SS 1LE Join Date: Oct 2019
Brake Ducts
I can’t find anywhere.
OEM Z28 brake duct kit. GM Part # 23252398 Ive tried all dealerships. Anyone got a source that has them? |
03-23-2021, 08:54 PM | #2 |
Drives: 2015 1le Join Date: Feb 2021
Also interested!
03-23-2021, 09:15 PM | #3 |
Drives: 2010 2SS/RS Join Date: Dec 2009
You try eBay?
Orange Krush II
03-23-2021, 09:42 PM | #4 |
I have im going to try a friend that owns a body shop. Manufacturers are required to have parts available I believe 10 years after production
03-23-2021, 10:01 PM | #5 |
Banned
Drives: Camaro 1LE Join Date: May 2018
I believe it to be major components for up to 10 years. If you really look at a parts breakdown on say just the camaro, a lot of parts have been discountinued already.
03-23-2021, 10:22 PM | #6 |
Nothing on eBay.
Ive order and paid 7x. All refunded money and said discontinued. So looking everywhere. Id prefer that setup as i saw a set on a car and they looked and fit awesome. |
03-23-2021, 10:29 PM | #7 |
Banned
I have them on my car. Such a clean install that I forget they're there quite often.
03-24-2021, 06:31 AM | #8 |
I have a set on my 2010 with 2013 fender liners and it’s a tidy setup for sure even have a set of Gen6 deflectors
Orange Krush II
03-24-2021, 10:36 AM | #9 |
Been hearing that the factory brake ducts are becoming impossible to find.
When I did the Z06 brake upgrade, I wanted to pick up a set but everywhere I looked was "out of stock". Might have to engineer my own.
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Custom Mishimoto Oil Cooler, BMR Tunnel Brace, Custom Dual Mishimoto Oil Catch Cans, MSD Plug Wires, Mishimoto Radiator and Hoses, Melling High Volume/High Flow Oil Pump, Improved Racing Oil Pan Baffle Kit, Improved Racing Oil Pressure Bypass Delete, Improved Racing Oil Pick-up Tube Clamp. |
03-24-2021, 11:21 AM | #10 |
I might try to 3d print each end and use flexible brake ducts between if I can't find a set
03-24-2021, 12:24 PM | #11 |
03-25-2021, 10:34 AM | #12 | |
When I get slow enough, I will try to design up a bolt up system out of aluminum and use the same flexible ducts. We have a $40,000 3D printer as well, but the one guy that knew how to run it left years ago, and my boss doesn't want anyone messing with it because the resin it uses is around $800 a cartridge... So it just sits...
2013 1SS/1LE
03-25-2021, 11:26 AM | #13 |
No luck on finding a set in ohio my friends parts guy looked around for me. I did find intake tubes from Amazon for a mercedes that might work just have to make an adapter from round to the rectangle openings in the inerfenders
03-25-2021, 02:19 PM | #14 |
Goto the Z28 section an look for Pat he has a Z28 in the UK maybe can print the inner parts he was selling the outlet part into the fender well to attach a hose to.
Orange Krush II
