Old 03-28-2021, 02:30 PM   #1
dretoven
dretoven's Avatar
Drives: 2013 Chevrolet Camaro 2SS
20x10 +35 Offset Squared Setup at Stock Height
Hey gang, I just need a concrete answer before I bite the bullet and buy my ZL style wheels. I have a 2013 blue ray metallic SS, I got the car used from the dealership at about 20,000 miles and i haven't done anything to the suspension so i'm assuming its stock height. Im looking at running 20x10 +35 all the way around so I have the ability to rotate my tires. I plan to put 275/40/20 tires on all 4 wheels. Will I have any issues with rubbing and/or fitment with the 20x10 +35 setup at stock height??? What issues will I potential run into mechanically and/or visually?
Here is the link to the wheels I want to purchase:
https://www.phastekperformance.com/2...5.htm?CartID=1
dretoven is offline   Reply With Quote
Old 03-29-2021, 03:59 AM   #2
Avenging Orange
Avenging Orange's Avatar
You should be fine. I'm 20x9 +30. If you have doubts...call Phastek, Tire Rack or any wheel supplier..
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 03-29-2021, 08:54 AM   #3
Arogg
A legend in his own mind
Arogg's Avatar
Drives: 2010 2SS/RS M6
iirc that's the offset im running on my square 20x10 MRR wheel setup. I am running staggered tire sizes tho. I had it this way at stock height, and now at a 1.25 BMR drop and ive yet to touch the tires on any bumps
2010 2SS/RS "The Mistress"
Color matched OEM GFX / VIS Carbon Fiber Hood (absolute trash quality and customer service ) / Heritage Grille / 5% Windows / 30% Windshield tint with 5% visor strip / Tinted Exterior Lights / Streetfighter LA Spoiler / Morimoto XB LED fogs / LED sidemarkers / Airaid CAI / Hurst Short Throw / TSP LT's / No cats / No resonator / Corsa Xtreme Catback / Trifecta Tune / Factory amp replaced / 2 JL Audio 12's / MRR 228 Wheels / BMR Springs / Koni Yellows / R1 Concepts Rotors & Pads
2006 Dodge Magnum RT "The daily"
Arogg is offline   Reply With Quote
Old 03-29-2021, 09:35 AM   #4
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
20x10 +35 will work just fine, ran that setup for a while with no issues.
SSEssence is offline   Reply With Quote
Old 03-31-2021, 08:49 PM   #5
dretoven
dretoven's Avatar
Cool, thanks for all the help guys! I went ahead and ordered the 20x10 +35 set. Another question,I see a lot of posts stating that people are running 285/35 with there 20x10 +35 set up. What are the advantages/disadvantages of 285/35/20 vs 275/40/20??
Old 04-01-2021, 07:01 AM   #6
KillboyPowerhead
Drives: 2015 Z/22
285's are wider so they'll have more grip; their smaller sidewall will have less flex which will potentially give the car more stability while cornering (less lateral movement) or hitting bumps (stiffer/less springy), but unless you're racing I wouldn't be concerned with this. A smaller sidewall will create a bigger gap between the tire and fender and also lower the whole car slightly.
KillboyPowerhead is offline   Reply With Quote
20x10, lowering kit, offset, tires, zl1 wheels
