Old 03-29-2021, 05:20 PM   #1
mactube
Drives: 2015 Camaro Convertible
Transmission Leak
Can somebody tell me what kind of silver cap this is on the bottom of my 2015 camaro V6 Transmission ? After wiping it off a little drop shows up about 15 min after, ( see pics) so the puddle of transmission fluid after one night looks like this :
https://drive.google.com/file/d/1Bqu...ew?usp=sharing
https://drive.google.com/file/d/1nMl...ew?usp=sharing
https://drive.google.com/file/d/1uGs...ew?usp=sharing
2x 2015 Convertible 1LT
- White on Black 22”s
- Silver Stock
mactube is offline   Reply With Quote
Old 03-29-2021, 05:50 PM   #2
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
Wish I had answer my friend but I do not. Is that plug on the bottom of the trans ?
HOJO is offline   Reply With Quote
Old 03-30-2021, 01:31 AM   #3
mactube
Yes it’s on a bottom of the transmission, I just came from a transmission shop and the buy who was there rebuilding transmissions .. said : Don’t worry about it its just a cap ,, you can pop off with a screw driver .
.. the leak doesn't come from there. it comes from the inside the transmission closer to the clutch converter.. and shows me on an open transmission which seal high hat to be replaced.
I’m thinking about adding "blue devil stop transmission leak product “ to it, to see what happens.
- Silver Stock
Old 03-30-2021, 07:37 AM   #4
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
That looks like the torque converter cap - your trans front seal may be leaking
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 03-30-2021, 09:55 AM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
That is the access/sight cover for the trans that keeps dirt and debris out of the bellhousing. It looks as though as Big said, you might have a pump seal going bad in the front of the trans. Mine leaked in there when my previous torque converter went bad. Also when my engine rear main went bad, it leaked from in there also. Good luck..
Old 03-31-2021, 06:42 AM   #6
mactube
Thank you guys, yes I have hear that a couple of times not bad seal ..
hopefully one hat can easily be replaced .. or main or pump seal or bushen.
I was debating if I should use blue devil seal fix fluid product , but I think that might cause problems with the rest of the transmission.
I will keep you guys updated on here.
- Silver Stock
