Old 03-31-2021, 02:18 PM   #1
Glassman66
Glassman66's Avatar
Drives: 2014 Camaro 2SS/RS 1le
Took a shot at repairing my wheels myself
A little over 3 weeks ago a dumbass ran me into the curb. It happened really quick, it was either get hit or evade into the curb. Either way after, calling a few run repair shops and not getting what I wanted to hear... Mainly a call back, I decided to repair then myself.
My wife was the one who pushed me to give it a shot, so I did.
I dismounted the right front tire and moved it to the left because the lip of the tire was chewed up. I busted the tire off the rim lip (we have a tire machine a work) had at it.
If I was to do the again I would have left the tires off the rim until I was done.
I tried liquid steel to fill in the damage at first Android although it worked, it was a pain to get a uniform fill, and a pain to sand.
I looked around the internet at what others had used and found glazing and spot puddy.
The glazing and spot puddy worked great. Dried quick and sanded easy. On the ZL1/1LE rims it was easy to block sand, but there is a lot of contouring between spokes. I just took my time and worked the detailed parts by hand. Then I used filler primer to get the fine stuff. After priming and standing 3 times I was happy and hit it with color.
For the black paint I used duplicolor HPW104. It's a close enough match. I didn't clear the wheel after painting, well see how it lasts. Looks really close to factory.
If the paint wears poorly, I'm going to paint them all in a satin plane propeller epoxy.
Either way I'm glad I tried this, they came out great in my opinion.
https://www.camaro5.com/forums/image.php?type=sigpic&userid=124840&dateline=15563  941302014 Camaro 1LE SS/RS THE MISTRESS
Glassman66 is offline   Reply With Quote
Old 03-31-2021, 02:30 PM   #2
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Disaster averted. Looks great.
Old 03-31-2021, 03:40 PM   #3
Roamer63
Roamer63's Avatar
Drives: 2014 camaro 2ss/rs
Looks great! What did you paint the calipers with?
Roamer63 is offline   Reply With Quote
Old 03-31-2021, 03:55 PM   #4
witenite
witenite's Avatar
Drives: 2010 2SS non RS
Nice work!
witenite is offline   Reply With Quote
Old 03-31-2021, 04:44 PM   #5
Glassman66
Glassman66's Avatar
They came from the factory that way,I think it's part of the 1LE package.
Old 03-31-2021, 05:23 PM   #6
Tarendor
Tarendor's Avatar
Drives: 2012 camaro 2ss rs L99
Looks great, and I bet it feel as good knowing you fixed them.
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
Tarendor is offline   Reply With Quote
Old 03-31-2021, 06:55 PM   #7
Glassman66
Glassman66's Avatar
That's always a great feeling
Old 03-31-2021, 06:59 PM   #8
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Awesome job sir!!! Nice work...
Old 03-31-2021, 07:15 PM   #9
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
Pat yourself on the back...awesome job
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 03-31-2021, 08:26 PM   #10
IlikeMyCamaro
Drives: 2010 2LT/RS IOM
that looks fantastic! great job!
IlikeMyCamaro is offline   Reply With Quote
Old 04-01-2021, 12:07 AM   #11
Ponchonutty
Ponchonutty's Avatar
Drives: 2012 SS L99 Converible
Looks fantastic. I really wanted that style of rim but couldn’t find what I thought was worth the price so I redid mine too. When I bought this the rims were curb checked. I took them to a powder coater. Told them I didn’t want black l, didn’t want silver and didn’t want chrome but I did want them cleared. Wanted gun metal or something close. Well, I got flat silver with no clear Couldn’t stand it so I did it myself. At least they don’t look like plastic anymore.
2012 L99 Convertible SS
Tooley Racing Stage 2 DOD delete, 3,200 stall converter, Shorty headers and custom stainless exhaust, CAI, and tune as mods
Ponchonutty is offline   Reply With Quote
Old 04-01-2021, 12:33 AM   #12
ariZona28
Give speed a chance
ariZona28's Avatar
Fantastic job and saved yourself some good coin. Next time somebody tries to guide you to the curb don't fool around, put 'em inta da wall!!!
ariZona28 is offline   Reply With Quote
Old 04-01-2021, 04:57 AM   #13
sdynak
Drives: 2010 1SS
Where do we send our wheels to for repair?
2010 1SS LS3, Black, 235/250, .621/.615, 114 + 4, Kooks Stepped Headers, 3.91's, Bo White PTB, Flowmaster Mufflers, Cold Air Industries CAI, Apex Scoop & Windshield Washer Relocate, SLP Wheels, Skip Shift Eliminate, Barton Flat Stick, OEM HID/Halos, Dyno Tuned by ECS
sdynak is offline   Reply With Quote
Old 04-01-2021, 05:27 AM   #14
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
Looks really good!
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
gunchamp is offline   Reply With Quote
