![]() Drives: 2015 chevy camaro 2lt Join Date: Sep 2020
v6 cams
Are there any performance cam options for the V6 LFX engine?
![]() ![]() Drives: 2015 Z/22 Join Date: Aug 2015
Mace Engineering out of Australia makes some: https://www.maceengineering.com.au/e...ducts/CAM669-A
I plan to install mine this weekend and will also be making a guide on how to do it (assuming all works out fine ![]() Check out the dyno chart here: https://www.camaro5.com/forums/showthread.php?t=484209. You can see the cams - when properly tuned - not only make a fair bit more power at 6700 RPM, when the factory cams stop making power, but they keep making power to ~7500. Factory redline/limiter is 7150 but when I got my tune from Will @ Overkill he bumped up my limiter to 7400 (completely stock engine), and he knows these engines pretty well. Mace also has stiffer valve springs if you desire but I asked Will and he said he wouldn't recommend increasing the limiter past 7400 even with the stiffer springs.
#3 | |
I'll definitely get it dyno'd when I'm done.
FYI I just attempted to do the install yesterday but lost a bit of confidence once I got to removing the high pressure fuel pump - it's pretty crowded back there and I wasn't sure if I would be able to remove the pump with the tools I had (not sure if anything specific is needed). Removing the pump requires removing the fuel piping, however, once removed the piping should be replaced with new, and I didn't want to remove them to find out I still couldn't get to the pump and thus blow $300 or so for the stupid piping since they can't - or shouldn't - be reused. I'm going to reach out to people who have done the install, or at least replaced the pump before, and then take another crack at it.
![]() Drives: 2011 Camaro 2LT Join Date: Oct 2018
Check out this thread from the Caddy forum on replacing the LLT HPFP. LFX is about the same but perhaps slightly easier since it has one ore more swivel connectors vs the LLTs fixed connectors that don’t have much slack in them.
https://www.cadillacforums.com/threa...ement.1088243/ Good luck! Last edited by Pearlj10; 04-03-2021 at 06:54 PM. Reason: Forgot to post link. |
#6 |
Thanks! I remember seeing this thread before. You wouldn't happen to know if you need to remove a coolant line for the LFX? I can't remember but I don't think there was a coolant line in the way like there appears to be on the LLT. None of the manuals say to remove a coolant line either.
My only fear is potentially wasting $300 or so of the one-time-use piping if I still can't get the pump off with the tools I have, otherwise I'd just give 'er. From what I've seen in videos and pictures it looks like just common tools and the flare nut crowfoot are all that's needed. I'll take another crack at it in a couple of weekends.
#7 |
I’m not sure about the coolant line on the LFX. Did you check out Rock Auto for those fuel lines? I remember seeing them on their site and not cringing too much at the price.
https://www.rockauto.com/en/catalog/...,fuel+rail,832 |
#8 |
I already have the piping which I bought from the dealer - although the dealer prices might be a bit higher I don't have to pay shipping or possibly exchange rate (live in Canada) so in the end they were about the same price, and were a little over $300 for both if I recall.
One pain as mentioned in the Caddy forum is the LFX rail pressure sensor/connector being right beside the low pressure piping connection and in front of the lower pump mounting bolt - if it wasn't for this stupid placement I think it would be a breeze. I think I've seen enough regarding the removal/install of the HPFP on other LFX and LLT variants that I think I'll just remove the piping and go for it; just need to wait for a weekend since it's a DD.
#9 | |
![]() Drives: 2001 Camaro Join Date: Jan 2018
