Old 04-02-2021, 08:01 AM   #1
rangerdave1
rangerdave1's Avatar
Drives: 2010 Camaro 2SS/RS LS3
Koni orange or Pedders struts??
I have 1 inch Hotchkis springs, trying to decide between Koni Orange struts or Pedders, both are similar in price and available.
Any opinions?
rangerdave1 is offline   Reply With Quote
Old 04-02-2021, 08:11 AM   #2
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
I was thinking of going koni orange (or maybe coil overs in the future). Only because the peddlers seem to need a slight modification to make them fit better. Plus koni and bmr springs are sold together in package deals because they fit perfect together. Also heard hotchkin springs also fit perfectly in them
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 04-13-2021, 11:24 AM   #3
rich2342
rich2342's Avatar
Drives: 2010 CGM Camaro SS
I am looking at the koni's for the same reason, no drilling.
Did either of you go with them? The 1LE's are hard to find.
rich2342 is offline   Reply With Quote
Old 04-14-2021, 09:45 AM   #4
Redgt03
Redgt03's Avatar
Drives: 2011 Camaro SS
I have the pedders for about 7k miles now, lowered on BMR 1.4 springs and I like them alot - nothing had to be drilled for the install.
2011 SS -GPI SS3 vvt, circle D 4c, 3.91 gears, solo mach xl exhaust, speed engineering headers, bo white ported throttle body, Roto fab intake, adm transcooler, elite catch can
Redgt03 is offline   Reply With Quote
Old 04-14-2021, 10:13 AM   #5
rich2342
rich2342's Avatar
Interesting. Oh, did you upgrade the rear to FE4 lower control arms?
Old 04-14-2021, 11:29 AM   #6
racesloth
Dan
Drives: 2010 Camaro 2SS IOM
I have the Koni oranges with BMR 1" drop springs and I think they ride too harsh.
If I was doing it all over I would prob go with the Pedders.
I have a complete set of 1LE struts and shocks in the wings to put on, but I may go a diff route looking to improve drag launches.
Dan
2010 IOM SS
YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust
http://www.camaro5.com/forums/showth...&highlight=ysi
racesloth is offline   Reply With Quote
Old 04-14-2021, 11:39 AM   #7
rich2342
rich2342's Avatar
I just ordered both. Got the koni's today and was able to find the 1LE suspension only.
I can't find the rear mounts anywhere. I am told Regular SS mounts, 1LE or Z/28 should work.
Did you get the rear strut mounts with yours?
Old 04-14-2021, 12:10 PM   #8
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
Sorry, I dont mean to hijack this thread.. but I have been looking at new struts/coiloivers as well and have been thinking about the Koni's. Just curious on what rear mounts you are looking for?
Tuned by Ben @BWTuned, GPI 416 w/GPI S/C Cam, GPI Ported Heads, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump/DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Rossler T400 w/t-brake, Circle D Converter, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Wiles Racing Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
Old 04-14-2021, 01:00 PM   #9
rich2342
rich2342's Avatar
Ashen, I am looking for the 1LE rear strut mounts. I actually just got the Koni's if you are interested? I couldn't find the individual 1LE parts I needed, until I actually did ordered them. I was in a rush do to an appointment for the work to be done.
But the 1LE mounts basically
Old 04-14-2021, 08:53 PM   #10
Ashen 6.2
Ashen 6.2's Avatar
Gotcha - What part number are the Koni’s?
Old 04-14-2021, 08:57 PM   #11
rich2342
rich2342's Avatar
Old 04-18-2021, 04:05 AM   #12
Avenging Orange
Avenging Orange's Avatar
I know in the past Konis had some issues. I'm assuming by now it's been corrected. You can find the individual 1le shocks/struts on rock auto.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 04-18-2021, 12:12 PM   #13
Ashen 6.2
Ashen 6.2's Avatar
Thanks rich2342. I'm trying to find something that will help with the drag set up so not sure what I will be doing just yet.
Old 04-19-2021, 07:41 AM   #14
Bigdumogre
Bigdumogre's Avatar
Have the link for this?
