Old 04-02-2021, 02:40 PM   #1
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
WHAT SPARK PLUG AND GAP
Hey guys, so ESS system is on its way. You can see my engine mods in my sig already. I'll be running roughly 10lbs. Seems most run an NGK TR7. What gap would you guys run? Thanks
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
gunchamp is offline   Reply With Quote
Old 04-02-2021, 03:02 PM   #2
RupertPupkin
Drives: 2014 Camaro SS 1Le
0.028" - 0.032" my new tuner put me in that range.
Juiced motor sports didn’t even gap my plugs correctly, hence why I was breaking up at high rpm (sigh****)
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 04-02-2021, 03:04 PM   #3
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
0.028" can carry you up to 13-15psi boost and still get a nice idle
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 04-02-2021, 04:35 PM   #4
gunchamp
gunchamp's Avatar
Awesome, thanks guys. So the NGK TR7 is good to go as well?
Old 04-02-2021, 04:43 PM   #5
G8One2
Drives: 2014 Camaro 2SS
Best thing to do would be to read your plugs, and not just throw in whatever.
G8One2 is offline   Reply With Quote
Old 04-02-2021, 05:19 PM   #6
RupertPupkin
That’s what I use, and theyve been great.
730whp: 630Trq
Old 04-03-2021, 07:44 AM   #7
gunchamp
gunchamp's Avatar
Awesome, thank you very much!!
Old 04-03-2021, 10:18 AM   #8
Rem0v3r
Drives: 2013 ss2 vert l99
Br7ef at 28-30.. if its not misfiring at WOT then you dont need a tighter gap.
Rem0v3r is offline   Reply With Quote
Old 04-04-2021, 07:08 PM   #9
brick59
Sucker Punch
brick59's Avatar
Drives: 2013 Black ZL1, 2022 Silverado ZR2
NGK TR7 .028 - .030, 15 - 17 PSI no break up and good idle.
427 Dart SHP Pro LS Block, Callies Magnum Crank, Callies Ultra I Beam Rods, Diamond Pistons, AGP twin Turbos 6865, Mast heads, Cam Motion LLR cam, Morel tie bar lifters, Crower roller rockers, NW 103MM TB, ID2600 XDS, Fore Triple, DSX, E85, ARH Turbo Headers, Corsa, Jakes stage 5 4L80, Circle D, RPM Roll Bar, BMR, Carlyle Racing 15" conversion kit.
brick59 is offline   Reply With Quote
Old 04-04-2021, 09:55 PM   #10
eLeSthree
Drives: 2011 Camaro SS 6sp
Ive run the ngk tr7ix at 32 and the ngk br7ef at 32. I dont see any real difference between the two perfomance wise. The br7ef is copper non projected tip plug, which is supposedly safer if you’re planning on running alot of boost. They are much cheaper... like $2 each. If staying arpund 10psi I would probably stay with the IX plug, but theyre expensive, maybe have a slightly better idle. Thats what Jannetty recommends anyway.
Great to hear another ESS kit going into a camaro. Let me know if i can help in anyway.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 04-05-2021, 10:53 AM   #11
gunchamp
gunchamp's Avatar
I really appreciate that!
Old 04-05-2021, 03:20 PM   #12
bayarea408
bayarea408's Avatar
Drives: T
Tr7ix has been good to me. I had ZR1 acdelco plugs and a tuner recommended i swap for these before the tune, Zero break up. They come ready to roll out the box as well, no need to fuss around.
bayarea408 is offline   Reply With Quote
Old 04-06-2021, 12:03 AM   #13
gunchamp
gunchamp's Avatar
Great to hear. I gapped my tr7s at .30. Should be good to go
