![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS, 2017 Silverado LTZ Join Date: Jan 2007
test
![]() Drives: 2012 camaro 2ss rs L99 Join Date: Feb 2017
Passed
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
![]() ![]() ![]() Drives: Camaro Convertible 2014 1LT Join Date: May 2019
A++++
With flying colors!!
Drives: 2013 Sparkly Red One Join Date: Dec 2018
I just wanted to be be the 70th person to view the thread. I couldn't leave it at 69.
#6 |
Ahhhh but 69 is a good number !!! lol.
#7 |
![]() ![]() ![]() ![]() Drives: 15 Camaro SS Join Date: Oct 2018
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
#8 |
#9 |
Thanks guys for all the nice compliments. She is 11& 1/2 years old with 69K miles on it. It's been from Florida to Canada. To TX and to MI 10 times.
