04-03-2021, 09:41 AM | #1 |
Drives: 2012 Camaro SS Convertible 6MT Join Date: Jun 2020
Cameras no longer work - post cam1/pioneer install
Hi all,
Hoping I can get some help here because I'm stuck. I previously had a PAC dash kit, along with a kenwood dmx7706s. Worked fine, but couldn't stand the glare. So, I decided to get rid of the PAC and go to the idatalink maestro cam1 and pioneer 4660nex. Hooked everything up and neither of my aftermarket cameras work now. I just get a black screen. - Rear camera is connected to the brown rear camera input on the deck - Front camera is connected to the yellow 2nd camera input on the deck - I previously didn't have the red wire connected to the deck harness, but since it wasn't working, I went ahead and tapped the two in with a quick tap. Still nothing. (I guess maybe the tap didn't sufficiently tap into the harness wire?). I tapped into to red accessory wire. - ON EDIT: Retapped the accessory wire and still not working. Leads me to believe this is a setting issue in the pioneer or cam1??? - Front and rear power and grounds are the same that worked before, so that can be ruled out. - I did enable all camera features when setting up the CAM1. - My stock camera in my rearview mirror does still work - it's just the aftermarket ones that are black screens. Anyone have any advice? Is there something else I could be missing? Thank you very much for your help!!! Mike Last edited by DMan918; 04-03-2021 at 10:37 AM. |
04-03-2021, 10:53 AM | #2 | |
Drives: 2011 2SS/RS Join Date: Feb 2016
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels •Vararam Ram Air Intake •Speed Engineering Longtube Headers w/ Magnaflow HF Cats •Bo White PnP Stage 2 TB •GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression •Xpipe w/ Res Delete and NPP Exhaust •Tuned By Anonymous Calibrations •Gen5DIY Mylink Conversion W/ Backup Cam •Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle •Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp |
04-03-2021, 10:54 AM | #3 |
04-05-2021, 12:15 PM | #4 |
Anyone?
04-15-2021, 03:37 PM | #5 |
For reference, I figured it out. When I had my Kenwood, I could connect the power to the turn signal lead and the ground to any good ground source. On the pioneer, the only way it would work was if I connected power and ground to the accessory and ground of the radio itself. Not sure why that was the case, but that's what was necessary to get things working.
