Old 04-05-2021, 10:36 AM   #1
Lnch Mny
Lnch Mny's Avatar
Drives: IBM Camaro
KW or Pedders?
Been looking at KW or Pedders Coil overs. Don't track the car enough to justify the big dogs, but would like to upgrade to entry level coil overs. The Pedders were out of stock for awhile so I had been looking at KW. Never heard of KW before, but the more digging I did the more they seem to be on top of there game. Feel free to share any opinions you might have on the subject.
Lnch Mny is offline   Reply With Quote
Old 04-05-2021, 02:54 PM   #2
Scotty D
Drives: 2014 1le 1SS CRMT
They have been around for years mainly import cars !!
I did pedders myself
Got them used
And i couldn’t be happier
Scotty D is offline   Reply With Quote
Old 04-06-2021, 07:56 PM   #3
KnoxSS1LE
Drives: 2013 SS1LE
KW all the way! Have always splurged on suspension in the past. Did KW coilovers and full Detroit Speed suspension. Couldn't be happier. First mod was Michelin Pilot sports and can literally throw the car into a corner. No roll, hop or slide. Never had a car handle like this. Haven't even played with damping yet.
KnoxSS1LE is offline   Reply With Quote
Old 04-06-2021, 09:29 PM   #4
Avenging Orange
Avenging Orange's Avatar
They are both good products. I have always been a Pedders fan.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 04-07-2021, 05:54 AM   #5
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
I did Pedders simply based on the amount of positive feedback I read on the forum. I love them, no complaints.
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 04-07-2021, 07:59 PM   #6
KnoxSS1LE
Drives: 2013 SS1LE
Like the way it sits. Good looking ride. Any sound clips of motor? Getting ready to do very similar setup.
Old 04-07-2021, 08:47 PM   #7
Clarkstar
Clarkstar's Avatar
https://youtu.be/mqUVTySBQoA
Old 04-07-2021, 08:50 PM   #8
Clarkstar
Clarkstar's Avatar
https://youtu.be/8qs5M5o86N0
Another...
Old 04-08-2021, 09:01 PM   #9
KnoxSS1LE
Drives: 2013 SS1LE
That's freaking awesome! Exactly what I want. Thank you for the post
Old 04-12-2021, 01:38 AM   #10
meldron
Drives: 2013 Camaro SS
Both are good. The Pedders are just easy to adjust based on my experience.
meldron is offline   Reply With Quote
Old 04-30-2021, 10:28 AM   #11
jethrobandit
jethrobandit's Avatar
Drives: 2013 Black 2SS
I'm looking at KW coilovers, which version did you go with? I was looking at either variant 2 or 3. And how low did you set them initially?
2013 2SS ::: MiSSy
BTR Stage 3 :: GM 3.91 :: Eaton TrueTrac :: SW LT Headers :: Elite Catch Can :: CAI :: ADM Cold Scoop :: VMAX ported TB :: Forza 3Way :: BMR Lowering Springs/Toe Rods/Lower CA/Trailing Arms/Subframe Bushings
jethrobandit is offline   Reply With Quote
Old 05-03-2021, 02:34 PM   #12
Lnch Mny
Lnch Mny's Avatar
Drives: IBM Camaro
I ended up going with Pedders. They were a little cheaper and in stock.
Old 05-20-2021, 09:20 AM   #13
kleanSS
Drives: 2011 SS
Where did you end up ordering them from? Southernautoparts canceled my order due to backorder with no ETA.
kleanSS is offline   Reply With Quote
Old 05-23-2021, 10:10 PM   #14
Lnch Mny
Lnch Mny's Avatar
Drives: IBM Camaro
Got them from phastek. Don’t forget to use coupon welcome5.
