Old 04-05-2021, 02:07 PM   #1
DonM
Camaro #4
DonM's Avatar
Drives: 2017-Hyper Blue Metallic-2LTmanual
Is my rear end going out? UPDATED
At first I thought it was my new tires making the noise, but today I realized that the noise I'm hearing is only coming from the back of the car. At first it sounded like I was running truck mudder tires, but now it's a definite, LOUD howling from the back of the car and it's speed variable - the faster I go, the louder it gets. But if I'm in a turn, it quiets down some.
The car has just under 140K, I don't do burnouts or hard launches (I just drive fast).
Any thoughts, ideas or options? Thanks.
Don M
Supercharged LGX + 6 speed manual = FUN!!
DonM is offline   Reply With Quote
Old 04-05-2021, 02:09 PM   #2
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
Wheel bearings? Axle? Ring and pinion?
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 04-05-2021, 03:33 PM   #3
KillboyPowerhead
Drives: 2015 Z/22
What that mileage my first guess would be a wheel bearing. Is it quieter when turning both left and right or just one direction? If you end up replacing a bearing I'd do both as they other is likely close to its end of life as well.
KillboyPowerhead is offline   Reply With Quote
Old 04-05-2021, 03:34 PM   #4
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
When was the last time you changed your diff fluid?
Could have a seal that went bad and you leaked out the fluid.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 04-05-2021, 04:29 PM   #5
DonM
Camaro #4
DonM's Avatar
I changed the trans and the rear end fluids at around 50K to AMSOIL products.
Don M
Old 04-05-2021, 04:42 PM   #6
Bigdumogre
Bigdumogre's Avatar
90k miles is a long time. Did you check the level of the fluid in the diff?
Old 04-05-2021, 04:52 PM   #7
ChibiBlackSheep
Definitely pull the top plug and reach in to make sure you have fluid in there still.
But if you haven't noticed a leak, I would do a drain and fill and then see if the noise is still there.
Old 04-05-2021, 04:53 PM   #8
DonM
Camaro #4
DonM's Avatar
I made an appointment with my shop on Thursday.
Don M
Old 04-05-2021, 07:06 PM   #9
Bigdumogre
Bigdumogre's Avatar
Hope it’s nothing serious aka expensive lol keep us updated
Old 04-05-2021, 07:16 PM   #10
DonM
Camaro #4
DonM's Avatar
Well, I've made myself paranoid thinking about how loud it was today (my mom and I had difficulty TALKING it was so loud), so I'm driving the wife's beater Exploder. I'm not going to drive the car again until I take it to the shop. The last thing I need is for my diff or a bearing to break loose at 80 mph on the highway.
I'll post what it was & how much Thursday evening.
Don M
Old 04-06-2021, 12:16 AM   #11
taz1727
taz1727's Avatar
Drives: 13 Camaro 2SS/RS LS3
Keep us updated, mine makes a howl sometimes in 4th gear. Speed variable as well
K&N Intake/ Pray Ported TB/ GPI Rod-Mod Intake Manifold/ GPI Ported Heads/ GPI SS3 Cam/ TSP 1-7/8" LTH to NPP/ Z/28 Diff/ Hendrix Offset Bushings/ BMR Delrin Cradle Bushings/ Pedders 27/32mm Sway Bars/ 1LE Shocks & Struts/ BMR 1.25 Springs/ Mishimoto Catch Can
taz1727 is offline   Reply With Quote
Old 04-06-2021, 12:19 AM   #12
DonM
Camaro #4
DonM's Avatar
Mine does it in all 6 gears - at highway speeds, it SCREAMS. The more I think about it, I think it's the left rear tire/bearing. I can hear it window up or down.
Don M
Old 04-06-2021, 08:08 AM   #13
ChibiBlackSheep
Yeah that does sound more like a bearing than the diff.
Old 04-06-2021, 01:55 PM   #14
ElderJ
ElderJ's Avatar
Drives: 2014 Camaro 1LT
On a side note, only in a car forum of guys is the question "Is my rear end going out?" appropriate...
ElderJ is offline   Reply With Quote
