Old 04-07-2021, 08:09 PM   #1
riozlander
that guy <--------
riozlander's Avatar
Drives: 2012 camaro V6 LS M6
dropped my V6 MT off for trans issues
I dropped my 2012 off today at aamco for a estimate of the trans today.
I'm sure with the track record I've had with this car its going to be a hilarious disaster. ive spent the the majority of 4 years driving on a broken aisin ay6 with the 2end gear pop out grind and binding problems on all gears.
back in november i drove out to Irving Texas on the trans in this state and back home. 1208 miles both ways on the way home was 16 hour strait shot 5-10 min rest for the car and tire check. finally have the cash flow to poke around on what it will coast to fix it.
figured mind as well make a post to document the adventure on the beater 5th gen in its journey
riozlander is offline   Reply With Quote
Old 04-10-2021, 08:43 PM   #2
riozlander
that guy <--------
riozlander's Avatar
well car needs, dual mas flywheel, new clutch, new clutch plate, throwout bearing, clutch master cylinder, about 2300$ in work and cars going to be away for 1 week or longer.
the clutch master cylinder is going to be i believe the newer one so the 2end gear and low pressure that was causing the clutch to not disengage fully, should not be a problem anymore i hope.
I know a lot of people here don't like me or think im full of S**t but there is a whole thread on this Trans problems from the factory https://www.camaro5.com/forums/showthread.php?t=91813
Old 04-11-2021, 08:30 AM   #3
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
So...there’s nothing wrong with the tranny? I can’t see the clutch causing it to pop out of gear.
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 04-11-2021, 07:03 PM   #4
riozlander
that guy <--------
riozlander's Avatar
from my understanding its the clutch master cylinder not having enough pressure to fully disengage the clutch so its still partially engaged and causes the miss/grinding on second gear and binding issue with other gears. mine is a bit worse case.
not having the money to fix it tell now and driving on it like that for 4 years. there pretty much is not a clutch left its metal on metal and my pop out is on De- accel.
my guess is with the clutch worn down when in 2end gear on de-accel its slipping and grabbing is causing it to pop out of gear im not a transmission guy nor will ever claim to be one. i just want the damn thing to work right for once
i got the manual trans because i was sick of Automatic trans problems. i come to manual week 1 of owner ship is problems
never had problems like this when i was operating a 12 speed in a Freightliner with a DD15. going cross country for Long Haul with Swift Transportation.
what i know of thew Aisin Ay6
From Wiki:
"The AY-6 is a 6-speed manual transmission manufactured by Aisin. It is designed for longitudinal engine applications and can handle up to (-->| 345 ft·lbf |<--) (468 N·m) of torque.
General Motors used the AY-6 as RPO MV1, MV5, and MV7.
Gear ratios:
1 2 3 4 5 6 R
4.17 2.19 1.49 1.19 1.00 0.84 3.67
Applications:
2004 Holden VZ Commodore
2005 Cadillac CTS
2005Toyota Tacoma
2006 Holden VE Commodore
2006 Lexus IS220d
2006 Lexus IS250
2006 Toyota FJ Cruiser
2010 Chevrolet Camaro
2010 Lexus IS200d"
i know the 2end gear grind is a common problem and the clutch master cylinder being weak is a problem. that's as far as my knowledge goes for the AY6 its self.......oh and parts are getting harder to get now half of mine are coming from Canada
Old 04-12-2021, 10:27 AM   #5
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Once the car is in gear the clutch is no longer in play. You can shift without a clutch completely and it will fully go into gear. Maybe you bent a shift fork. The clutch very well may need replacement, but that isn't your popping out of gear issue in my opinion.
Greenhornet2 is offline   Reply With Quote
