![]() Drives: 2014 Camaro 2SS Join Date: Mar 2021
Transmission question - overdrive
I have a 2014 SS with the automatic transmission. We just purchased the car last month with 103k miles. I replaced the trans filter and topped the fluid off with the car running. Everything shifts out smooth but I get the feeling that something is not right. At 80mph I am sitting at about 2100 RPMs and the car never seems to go into overdrive.
What am I missing here? |
Well for 1 thing it is an auto, so you could try driving it and shifting with the paddles on the back of the steering wheel while the shifter is in "sport/manual mode" and shift yourself and see if it shifts all the way up to 6th gear, which is the top gear. If so, check out your rpm's there. Someone may have done a gear swap on the car. Not too sure where mine is at when going 80, and is an auto as well.
#3 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
2100 sounds right for your car at 80.
I'm looking at a few logs from my SS right now and that is what I am seeing.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
#6 |
Checked mine out and I usually cruise at 75, so poked up to 80 and it is right about 2000-2100. So you are good, and I still have the stock gear in mine..Enjoy that ride!!
| Tags |
| auto, l99, overdrive |
