Old 04-09-2021, 06:40 AM   #1
eLeSthree
Drives: 2011 Camaro SS 6sp
Installation Instructions for Strange Front Coilover # 2063
After a 2 month wait I received the front coilovers. They did not come with install instructions, which seems to be the norm. I've searched online and no one seems to ever get instructions with them. I've found a few videos on youtube that helped, but they were using BC coilovers, and the mounting hardware/spacer/washer is much different.
My stock spring insulators were toasted, so I ordered a new pair and those arrived, but I still dont know the re-assembly order.
I know I need to re-use the stock insulator, bushing and mount, but I'm not sure if the first retaining washer/nut should be used, or if the weight of the car holds it in place until the top washer/nut is attached.
Has anyone else installed these recently? I'd love to see a pic of the assembly before its re-installed, and/or the correct order starting from the top of the spring up.
Thanks
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 04-09-2021, 06:45 AM   #2
eLeSthree
F it, i’m gonna run’em just like this.
1158whp 1017wtq.
630whp 658wtq
Old 04-09-2021, 04:14 PM   #3
bayarea408
bayarea408's Avatar
Drives: T
email strange those photos and ask directly man. You dont want suspension issue with this kind of power. I dont want to see something bad happen lol
Do not wing this!
bayarea408 is offline   Reply With Quote
Old 04-10-2021, 10:28 PM   #4
eLeSthree
I got it figured out thanks to a local guy (fifthgenpower) who sent me some pics of his. My spring insulators were shot so i ordered replacememts. Unlike the rear coilovers the front need a spanner wrench to adjust the ride height. Picked one up locally. Should have it wrapped up tomorrow.
1158whp 1017wtq.
630whp 658wtq
Old 04-11-2021, 04:59 PM   #5
eLeSthree
What a huge difference! I finally have traction again! The front end lifts as boost ramps in and keeps the rear tires planted. Money well spent!
Made more of a difference than switching from 18s to 15s.
1158whp 1017wtq.
630whp 658wtq
Old 04-12-2021, 04:22 PM   #6
bayarea408
bayarea408's Avatar
Drives: T
awesome!!! now once you dial it in and it leaves too hard you can chain the front down. hahahahaha
Old 04-12-2021, 04:48 PM   #7
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
Did you have to play much with the adjustment. If so was it simple to dial in? I’m sure you’re one happy guy, nothing better than when things come together.
HOJO is offline   Reply With Quote
Old 04-13-2021, 06:55 AM   #8
eLeSthree
I haven't touched the adjustment knobs yet and its already made a huge improvement. I think the car will settle a little after some miles, so I may need to adjust he ride height some, so i want to get that worked out before i start messing with the compression/rebound.
I sent an email to strange to see what they recommend, but I have a feeling it all depends on your setup, trans type, tire type, if you are hooking or spinning, if you are on prep or no prep, asphalt or concrete. I think I'm on my own.
With a proper alignment and the new slicks I bought, I hope to hook in second on the street. Of course, once I get that all figured out, I will have to start over for racing at the track, lol. Different ball game when you have traction.
1158whp 1017wtq.
630whp 658wtq
Old 04-14-2021, 11:32 AM   #9
racesloth
Dan
Drives: 2010 Camaro 2SS IOM
Happy for you man!
Dan
2010 IOM SS
YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust
http://www.camaro5.com/forums/showth...&highlight=ysi
racesloth is offline   Reply With Quote
Old 08-05-2021, 10:48 AM   #10
eLeSthree
Update
Finally got time for an alignment. The tech was cool and worked with me to get as close to 0 as possible, with maybe a touch of positive camber in the rear.
I've got the car where I can keep traction in 3rd gear with about 90% throttle above 5500rpms, but at 100% I can feel it spin. Definitely needs more fine tuning.
Does anyone else have this suspension? I'd love to hear how others have things setup. Anti-roll bar and compression/rebound settings, ect.
Need to learn suspension theory. Should I start adjusting things looser or tighter?
(also sent the G4-95 out to ESS to have their latest impeller installed)
1158whp 1017wtq.
630whp 658wtq
Old 08-05-2021, 03:28 PM   #11
eLeSthree
I heard back from Strange. Wierd they dont provide this document with every set of struts. Hope this helps someone someday. See pdf attached.
1158whp 1017wtq.
630whp 658wtq
