Old 04-11-2021, 09:03 AM   #1
Frankbarb
Drives: 2012 45th anniversary
Brembo Caliper Kit
Looking for brembo caliper rebuild kit front 2012 SS. Can't seem to find complete kit. Dust boots are getting soft and popping out of seat.i would like to replace seal and boots
Frankbarb is offline   Reply With Quote
Old 04-11-2021, 09:12 AM   #2
Omega
Drives: G8
Front piston and seal kit: 92244294
Front dust seals: CENTRIC 14303005
Looking through Rockauto, the parts above will give you everything you need.
Sent from my Pixel 4 XL using Tapatalk
Omega is offline   Reply With Quote
Old 04-11-2021, 09:14 AM   #3
cdb95z28
cdb95z28's Avatar
Drives: 2022 1SS 1LE A10 BCD WCT+PDR
rockauto.com is always your best friend:
https://www.rockauto.com/en/catalog/...epair+kit,1720
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
"KEEP THE FAITH"-Fbodfather
cdb95z28 is online now   Reply With Quote
Old 04-11-2021, 09:26 AM   #4
Frankbarb
Thanks
Old 04-11-2021, 09:54 AM   #5
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Just checked an RA is sold out.
Front piston and seals;
https://www.rockauto.com/en/moreinfo...501817&jsn=486
Front Dust Boot;
https://www.rockauto.com/en/moreinfo...501817&jsn=475
Front springs an pins;
https://www.rockauto.com/en/moreinfo...1817&jsn=10497
Rear Piston an seals;
https://www.rockauto.com/en/moreinfo...501817&jsn=485
Rear Dust Boot; currently sold out
https://www.rockauto.com/en/moreinfo...501817&jsn=476
But available on eBay;
https://www.ebay.com/itm/Genuine-GM-...4AAOSwbwVgWnNR
Rear spring an pin kit;
https://www.rockauto.com/en/moreinfo...1817&jsn=10496
Orange Krush II
Old 04-11-2021, 03:02 PM   #6
cdb95z28
cdb95z28's Avatar
CENTRIC 14303005 is still in stock @ rockauto. Includes dust boots and piston seal. You'll need two to do both calipers
