Old 04-12-2021, 12:13 PM   #1
king50
Drives: 2015 camaro ls
Differential hmming noise?
Hi,
My 2015 camaro has 85k miles on it. I changed the differential oil last month and started to hear humming noise when I turn at low or high speed. The humming noise doesn't happen when I drive straight forward or reverse. The oil I used was 75w-90 UltraPlus GL-5 approved. But it doesn't say limited slip additive on the bottle. So, today I changed the diff. oil. This time, I used the Valvoline 75w-90 with limited slip additive but still hear the humming when I turned. I even rotated the tires but the noise is still present when I turn. Any help diagnosing this issue is appreciated.
Thanks!
Rober
king50 is offline   Reply With Quote
Old 04-12-2021, 12:20 PM   #2
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
I would grab a bottle of the gm diff additive and throw in 4oz
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 04-12-2021, 12:39 PM   #3
redcoats1976
does the ls camaro have limit slip?i remember reading that manual shift 6 cylinders have limited slip but not sure about this.
Old 04-12-2021, 12:43 PM   #4
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
that is my understanding. Manual has the 218mm diff and Autos have the 192mm. 218mm is the SS diff and is LSD.
Old 04-12-2021, 12:52 PM   #5
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2020 S560, 2013 SS
Did someone say LSD?
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 04-12-2021, 02:11 PM   #6
gtstorey
It may take a little while for friction modifier to work it's way into the clutch packs.
Old 04-13-2021, 11:49 AM   #7
BostiPB
BostiPB's Avatar
Drives: 2014 Camaro 2SS/RS
Did you do any low speed figure 8s. You want to do some of them to work the friction modifier into the clutch packs.
2014 2SS/RS - Red Rock Metallic - Kooks Headers, Corsa Extreme, Factory Reproductions Z28 Rims, Pedders Coilovers, JDP Clutch Reservoir, Summit Racing Line Lock, GM Strut Brace, GM low profile splash guards, Roto-fab CAI, Oracle Ghosted Sidemarker Lights & Concept Mirrors, ZL1 Side Skirts, MGW Flat Stick Shifter, BMR Subframe Connectors, Eaton Truetrac, Yukon 4.11s, GForce Renegade Axles, Speedmaster79 Diff Cover, Offset Diff Bushings, Every Suspension Bushing Front & Rear Replaced with BMR Poly Bushings - 421HP 412TQ
BostiPB is offline   Reply With Quote
Old 04-13-2021, 12:16 PM   #8
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Only the manual v6 has a limited slip differential. This information and what fluid to use is of course in the Owners Manual.
Rock-It Man is offline   Reply With Quote
Old 04-15-2021, 07:25 AM   #9
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
sounds like it could be a wheel bearing. it is louder turning one way
Greenhornet2 is offline   Reply With Quote
Old 04-15-2021, 07:27 AM   #10
DonM
Camaro #4
DonM's Avatar
Drives: 2017-Hyper Blue Metallic-2LTmanual
I just had a noise coming from the rear that originally I thought was the diff. Turned out as it got louder, I could only hear it from the left rear and it was a wheel bearing.
Don M
Supercharged LGX + 6 speed manual = FUN!!
DonM is offline   Reply With Quote
Old 04-15-2021, 08:10 AM   #11
gtstorey
Same here. It happened shortly after I installed diff bushings and cover and sounded so much like the diff that I replaced it with a used one. It turned out to be hubs.
Old 04-15-2021, 08:58 AM   #12
king50
I don't think that it's a wheel bearing issue because a wheel bearing issue would also make noise when I drove straight. Also, when the engine is cold the grinding noise is loud but as I start driving for 10 minutes the grinding noise becomes softer. The grinding noise only occurs when I turn the steering wheel to the left or right. I did do the 8's pattern at very low speed but it didn't help. Some people told me to put in a bottle of the OEM additive, as after market stuffs aren't nearly as good as the OEM oil. I'll drain the oil and put in the OEM oil and OEM additive as the last resort before I take it into a shop.
Old 04-15-2021, 10:14 AM   #13
Greenhornet2
well a wheel bearing doesn't make noise going straight when it first starts to go. it starts making noise on turns as there is excess pressure applied. But since it is louder when cold and if it is making the noise at parking lot speeds on turns I would look at the clutches, add a half a bottle of the gm stuff and see what happens. at high speed the clutches really aren't moving much which is why it sounded more like a wheel bearing.
Old 04-15-2021, 11:43 AM   #14
Avenging Orange
Avenging Orange's Avatar
I've been a firm believer in non synthetic oils for years. Had same issue when I changed to 3.91's. Used the recommended synthetic w/friction modifier and still had noise. Switched to conventional gear oil with friction modifier and it is quiet as a mouse. Actually quieter than the factory gears. Worth a try.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
differential, humming noise
