![]() Drives: 2010 CGM Camaro SS Join Date: Dec 2016
1LE Shocks/struts or These?
Does anyone know if these pedders components are equal to or upgrade to the 1LE shocks/struts?
I have a 2010 and am doing the rear conversion as well, but I can't find the rear top mount for the 1LE rear as it seems to be discontinued. Are these pedders an upgrade in rebound/stiffness? I would be pairing with Hotchkis 1 inch springs. PEDDERS SUSPENSION SPORTS RYDER LEFT FRONT STRUT, DRIVER SIDE *Fits 2010-2012 Camaro For motorists who are after that extra level of performance and sports handling, Pedders SportsRyder shock absorbers are the ideal choice. The gas-charged GSR SportsRyder Strut range, uses nitrogen gas pressure to enable precise control without compromising on ride comfort. Our Gas SportsRyder range are a high performance, heavy duty replacement units which deliver a new standard of comfort and road holding ability Features & Benefits:
They have the mounts on eBay
22922445/46 about 50 bucks each.
Orange Krush II
![]() Drives: 2010 Camaro 2SS/RS LS3 Join Date: Jul 2019
I'm following along. I also have a 2010, and also have Hotchkis 1 inch lowering springs. From what I can see, pretty much all 1LE, Z28 parts are no longer available...
I ordered 2 suspensions. I got Koni orange f/r because i couldn't find the 1 LE's. Ended up finding them and accidently hit send on Amazon.. in the mail🤣🤣.
I did get mounts that are the heavy duty Z28 ones from Tasca online. |
![]() Drives: 2012 Camaro SS A6 SIM Join Date: Nov 2016
You can find the 1le shocks and struts on rockauto. That’s where I got mine. Did that and bmr lowering springs with 1le sway bars. Car handles great.
#6 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
#7 |
I found the AC delco part #'s on Amazon. It took me a while. not easy to search car parts on Amazon.
