04-15-2021, 03:33 PM | #1 |
Drives: 2012 Chevrolet Camaro Join Date: Feb 2021
Steeringwheel with led display
Hi I bought the steering wheel in the picture it works with a OBD blue tooth connector and only needs 12 volt behind the airbag,problem is as soon as I connect the display to 12 volts voltage drops to 3 volt or zero volts, I tried all the 12 volt connections available in all three plugs, is there a solution for this?
Edit: when I connect it to the cigarette lighter it works great,but this makes steering a little difficult Last edited by Peter La Romana; 04-15-2021 at 03:37 PM. Reason: more info |
04-15-2021, 11:24 PM | #2 |
Banned
Drives: 2010 LS Join Date: Feb 2021
They're made for the 2016+ Camaro. The instructions for installation on those, are
to use the two pin plug, with a brown wire, and a blue wire. Power for the device goes to the brown wire. The ground from the device goes to the blue wire. My guess is: The GEN5s, do not have enough AMPS to run it, which power comes from the BCM. 12V power for the wheel is on a 2AMP fuse. So, when you connect that to a 12V source at the wheel, the load is to high, so the BCM shuts it down. If it were a dead short, the 2A fuse would blow. What BRAND name is that one? Vicrez, is for 2016+ |
