Old 04-16-2021, 09:42 PM   #1
Coz3z3
Drives: 2015 Z/28, 2015 1LE
Clutch fluid bleed
Need help bleeding clutch fluid and slave cylinder. I’m having trouble with it. I loosen the fitting and have someone push the clutch in, then tighten it, release clutch, repeat. The pedal won’t get stiff. Am I doing this wrong? Thanks
Coz3z3 is offline   Reply With Quote
Old 04-16-2021, 10:08 PM   #2
SS Blinder
SS Blinder's Avatar
Drives: 2011 SS (Sparrow Spearer???)
I recall having to press the clutch A LOT to get it to stiffen up
Black magic woman, don't turn your back on me baby!
SS Blinder is offline   Reply With Quote
Old 04-16-2021, 10:11 PM   #3
Coz3z3
Yeah I have been trying that and bleeding and up down up down lol. I’ll try some more though. Anyone else have any ideas?
Old 04-16-2021, 10:33 PM   #4
Coz3z3
Did you bleed it from the slave? Or by doing the syringe method? I’m not doing the syringe method and it seems that’s what everyone has done on the internet. Not one thing about how to properly bleed it through the slave!
Old 04-17-2021, 08:28 AM   #5
fz4k98
Drives: 2013 1ss
I just did mine and it was a new slave and the lines were empty when i started. It took me about 80 to 100 pumps to get good fluid flow.
I did not tighten every cycle. My method was
Crack open about 1/4 turn or less
Pedal down quick
Thumb or finger over end instead of tightening
Pedal up slow
Repeat steps 2,3 and 4 until there is good fluid flow.
Then do the close it and pump up pressure like a normal bleed process a couple times until good pedal and no air.
fz4k98 is offline   Reply With Quote
Old 04-17-2021, 08:45 AM   #6
G8One2
Drives: 2014 Camaro 2SS
Pull a vacuum on the master cylinder. It will pull a majority of the air out. Then use the bleeder screw and someone pumping the pedal to get the rest of any remaining air out.
G8One2 is offline   Reply With Quote
Old 04-17-2021, 11:12 AM   #7
hudson773
Drives: 2014 camaro SS
there is a tool that works like a paint spray gun. you hook air pressure to it and attach the feed hose to the bleeder. open the bleeder and press the trigger. the suction effect pulls the fluid out into a jar. close the bleeder when it runs clean. the syringe method may remove part of the old fluid, but not all. the amount left surely has contaminants left in it. to me, that is a ryobi tool compared to a snap on tool. may be popular, but not right.
https://www.amazon.com/dp/B081GVKXLN...mcd_asin_0_img
hudson773 is offline   Reply With Quote
