![]() Drives: 2013 Camaro 2SS LS3 Join Date: Apr 2021
2013 Camaro 2SS Ls3 (Goal is to 550+Hp to the wheel)
Hello I am new to the Chevy world and I just got a 2013 Camaro 2SS and the only modification done to it so far is a cold air intake that was already on the car when purchased. I am making this because I want to eventually make at least 550+ to the wheel and I have no clue where to start in terms of modifications. Could you guys help me out?... if possible have a order in which I should have things done so I don’t mess anything up. Thanks in advance for the help! (PS I still would like to drive it as if it were my daily driver )
Last edited by KingDun34; 04-17-2021 at 10:13 PM. Reason: I forgot to add I still want to drive it as if it’s still a daily but I forgot to mention |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Turbo LS3 Join Date: Dec 2009
Leave it stock; you will save a fortune.
Otherwise, start with a pile of cash go get some form of forced induction.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. Gen6 ZL1 brakes. |
#3 | |
![]() ![]() Drives: 2013 Camaro 2SS/RS Join Date: Aug 2020
If I recall when I dyno my 2SS/RS 2013 I was at 350 hp stock to the wheel. I wish I could find the tests to confirm that. But the car turns 13.5quarter, equal to my stock 87 GN. Both have CAI. Last edited by BuddyLee; 04-17-2021 at 10:57 PM. |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
Turbo or supercharge kits will get you there no trouble. And you can still daily it. You wouldn't even need a cam with some of them.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
I'f I was you I would give Gwatney Performance and Texas Speed a call because they sell everything that you will need to get where you want to be and ask them what they recommend because they specialize in our cars.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
#6 |
Of course forced induction (pro-charge, supercharge, turbo...) will get you leaps and bounds quickly if you have coin for it. Not sure what you’re budget is but the motor needs to breath. Toss some headers and a full exhaust on to start. I am very happy with Texas Speed. If you plan to seriously peruse power and torque, go forced induction ASAP, slap meth injection system on. Charger pulleys upper and lower. You’ll need to find a Dyno for mods. Cam and internal upgrades will go far. Good luck brother!
#7 |
![]() Drives: 2013 1ss Join Date: Jul 2012
Set aside $10k to supercharge it and another $10k to fix all the broken stuff and tires.
#8 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
You could move to CA, spend what you would mod on the simple cost of living and risk a CARB beatdown or being cuffed for a muffler delete.
#9 | |
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
You need to decide if you are trying to do this NA or forced induction. NA can be done, but it is likely going to require an LLSR setup and some very nice (expensive) heads, and a different aftermarket intake manifold. The heads would need to allow increased valve angle so you can run a much larger cam and of course you would want to get that compression up a few points. The big problem here is that you are still going to be limited with displacement, which is where a stroked build would come into play. Most people wouldn't want to daily a build like this though...although I know more than a few here that would love to give it a go! Obviously there is much more to what I am getting at here for an NA build for over 550rwhp, but this can give you an idea of where you would need to be part wise.
Or you can take the easy route and go with a blower or turbo setup, as said above. There are plenty of ready fit kits for our cars that can take you well above 550rw reliably.
#11 |
Seriously, I wonder about the ‘reliability’ part. Sure, a whipple or maggy probably gets you there with one bolt on project. And I know many tout the trouble free miles they’ve DD’d theirs but if you drive it like I know I’d want to drive it, how long before this stuff goes?
Trans Driveline Diff half shafts I think the OP is aware but it seems even 550 rwhp is a pay to play prospect. Well beyond the initial price. But that’s the cost of fun, I guess.
#12 |
![]() ![]() ![]() ![]() Drives: 15 Camaro SS Join Date: Oct 2018
Supercharger or turbo is the easiest way to get to where you want to be. Its not cheap so be prepared. I built my top end first and it was fun. Now im installing a centri on top of that. Its a sickness lol, but not a cheap one
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
#13 |
Turbo and centri aren't as hard on the driveline because the power comes on later. If you don't put a big sticky tire on it and try to launch at a drag strip, things can last pretty well. I will say that I find the vert with an NA 416 build more fun to drive on the street than the turbo car, but 450whp is probably a more realistic goal for a DD NA build. As Infidevil said, 550whp NA is pricey and unruly on the street.
There are lot lots of things the OP is not considering, potential driveline issues being one. Just because you make a lot of power does not mean it will be a world beater. Lots of suspension and brake mods needed to make them truly fast cars. Also, everything that makes them faster, generally makes them less enjoyable for daily driving. In other words, he needs to decide how many reliability and drivability issues he can put up with. One thing that has not been mentioned is nitrous, but I don't view that as a good power for the street, albeit effective if you do it right and pay attention to what the car is telling you.
#14 |
Thank you all for the help! I really do appreciate it because as you all are telling me different scenarios I am learning a bit more and more with each response. However after looking through all of the responses so far I think I want to change my desire till about 450+ hp to the wheels while being NA. Solely because I am still new to this amount of HP as is, so I believe 450+ is more reasonable for me. So if anyone has any tips or set ups where I could reach this goal please let me know. This will still be used sort of as a daily, PS - could you list the mods in order to prevent any unnecessary damage
| Tags |
| 2ss, 5thgen, build thread, ls3 5thgen |
