![]() Drives: Camaro SLP ZL575 Join Date: Nov 2020
Rubbing issue with wider tires
I have bought new rims and tires for my ZL575.
It is lowered 1" with Eibach springs. Bought FR41 in dimensions 20x9 offset +27, and 20x10 offset +35. Tires are 275 / 40-20 front and 305 / 35-20 rear This is the recommended rim and tire size from Phastek. So to my question: I have seen videos on youtube that with this setup one will have problems with chafing at the rear wheel on the driver's side. The rear wheel on the driver's side will rub against the liner and potentially damage wires that run on the back of the liner. These wires must be moved aside on 6 gen. Will I get this problem on my 5 gen too, or is 6 gen different in terms of wheelhouse design Do I have to perform the harness relocation to be safe? |
#teamGPI
Drives: 2010 Camaro SS Join Date: Aug 2020
I have 315/35/20's on the rear and dont't have any rubbing issues at all, I think your good
Thanks for the reply L99MARO
What dimensions do you have on the rim? Is it 20x10 "or 20x11" What offset do you have on the rim? Do you know if the 5th-gen and 6th-gen are identical regarding the wire harness behind the back of the liner at the rear wheel on the driver's side? |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
I have a set of 305/45*17 and 315/35*20 and neither rubs. Also dropped over 1" on coilovers. It gets close on launch.
Ok Vegas Bound, thanks for the reply.
Hope this works, without the wheel wearing on the inner fender I'll be mounting aFe Rear Subframe Bushing Sets on it soon |
#6 |
Live to Drive
Drives: 2010 IBM RS/SS, 2018 Toyota Tacoma Join Date: May 2010
I also run a 315/35/20 on the rear with no issues. I am on an 20 x 11 wheel.
#7 |
I also run 315/35/20 on the rear's with a 20x11 wheel with a +43 offset, have run 335/30/20's also with no issues and am dropped 1.25. Also to answer your question on the harness behind the fender liner, it is only the 6th gens that have this issue. No body on here has ever had the problem, but if you go look on the 6th forum you will see it there. Good luck sir..
#8 |
Thanks so much for the great answers guys
This is what I like best about this forum, to get concrete answers to current issues. Thumbs up Looking forward to having the rims fitted tomorrow. This is my first 5th gen Camaro, and I love it the more I drive it. |
#9 | |
#10 |
![]() Drives: 2010 camaro ss white Join Date: Jun 2019
Check your E brake cable also,
Coop |
