Old 04-24-2021, 12:51 PM   #1
Crash76
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500
Started my Ridetech TQ Coil over install
So far just got the rear shocks off ... took a break to eat some breakfast.
Definitely remove the LCA from the knuckle... 10x easier to remove
Crash76 is offline   Reply With Quote
Old 04-24-2021, 04:18 PM   #2
Crash76
Team 913
Rear shocks are in the car. I have to button it back up the rear LCA and sway bar. Then figure out where to mount the canisters.
Old 04-25-2021, 01:01 AM   #3
Crash76
Team 913
Rear shocks done... just got to mount the canisters
Old 04-25-2021, 05:32 PM   #4
Crash76
Team 913
Fronts and rears done. Canisters mounted. Just need to find
Black bolts for the brackets.
Old 04-26-2021, 05:27 PM   #5
Wacko37
Wacko37's Avatar
Drives: 2010 2SS/RS & 2007 2500HD D-Max
I'd suggest to look at the DSE/JRI mounting of the canisters in the rear. mounting to the plastic on the bumper would make me nervous!!
2010 Summit white SS/RS, Manzo full exhaust w/2" primaries, Roto-Fab intake, FE4 conversion, JRI Coilovers built by Ult_Performance w/hypercoils, BMR sway, BMR trailing arms, UMI toe links, solid sub-frame bushings, upper control arm bushings, radius inserts, caster locks, Taylor wires, BTR spec'd cam, tuned by ECS, various little lighting mods, ebay SLP splitter, Heritage grille, ZL1 rockers, Apex 19x11 w/RE-71r's 305/30/19, eaton tru-trac
2007 2500HD Duramax, Built trans, custom tuned beast
Wacko37 is offline   Reply With Quote
Old 04-26-2021, 10:32 PM   #6
Crash76
Team 913
They are not particularly heavy ill check it out though... thanks!
Old 04-29-2021, 03:26 PM   #7
Crash76
Team 913
Havent bothered trying to tune the shocks for the street yet, just starting at the 20clicks recommended in the instructions. Ride is much better than mag ride with drop springs. I think my stock shocks were shot though ... oil on the shafts. I was able to get 2.5 deg of front camber with the plates that come in the kit.
