Old 04-26-2021, 04:50 PM   #1
FlowZl1
Drives: 2012 Chevy camaro ZL1
Cammed ZL1 misfires
Alright, new to the thread, and new to camaros as well. So forgive my ignorance. So I recently Cammed my 12 ZL1 (BTR STG3), all was good during break in and we followed everything to the t on assembly utilizing the LS benchmark build guid I bought off of Amazon. During break in everything ran as it should with signs of anything being out of place. After break in and oil change I got the go ahead from my tunner to start tunning and send her on home. Under WOT in any gear it would start misfiring under boost at 4 K, she was breaking up bad. We did all we could to locate the issue, check fuel spark air, checked ground, made a dimple in headers to clear steering rack, and a few other things. How ever she was still misfiring. I ended up replacing the SC isolator coupler as she went bad shortly after. Once I reistalled with Lifeinger coupler the engine started misfiring on idle, and under any load she would just bog down. The throttle also on a flat surface has to be about 10% engaged to move. I’m really lost at this point and I have literally no information on where to go from here. I need help bad 😅
FlowZl1 is offline   Reply With Quote
Old 04-26-2021, 06:07 PM   #2
JB'sZL1
Drives: 2013 ZL1 and 2019 Ram Laramie
Check the tune, and obviously, bad plugs or wires.
JB'sZL1 is offline   Reply With Quote
Old 04-26-2021, 06:11 PM   #3
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
1. Are you datalogging at all?
2. Is it a random misfire, or isolated to a cylinder or two?
3. Have you performed a compression test on all 8 cylinders?
4. What plugs and what's the gap?
5. Are you losing any coolant from the intercooler reservoir?
-Scott
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 04-27-2021, 10:22 AM   #4
xdamxincx
Banned
Drives: zl1 blk
did u upgrade your valve springs ?
xdamxincx is offline   Reply With Quote
Old 04-28-2021, 10:39 PM   #5
Mmcmon
Mmcmon's Avatar
Drives: ZL1
What type of misfires are you experiencing when you log all 8 cylinders on your scanner? Is a misfire occurring in small amounts like 1 to 6 times on random cylinders? Or is it like 1000 misfires on the same cylinder?
After installing a cam there are parameters in the tune that must be taken into account using the specs of your cam. Your valves are opening differently than stock now.
Mmcmon is offline   Reply With Quote
Old 04-29-2021, 10:08 AM   #6
FlowZl1
Ok so since I don’t have the laptop for tuning (it’s my buddies) i haven’t recently checked parameters, I will get it here shortly and set up to read each cylinder for misfires.
Plugs are gapped to .035, TR6IX, brand new wires as well. I have an extra set of plugs that are brand new that I can swap in. Just wasn’t sure if that would be the issue. Have not performed a compression check but I probably should, I’ll try these things and get back, I appreciate the response ! I have a few videos of it running I can upload I just don’t know how to upload them.
Old 04-30-2021, 12:07 AM   #7
CJ27
Drives: Chevrolet camaro zl1
Could be as simple as a cracked plug.
2014 Sliver ZL1. Built engine, Stage 1 Frankenstein heads, Magnuson, SW long tubes, AFCO H/E, She Gone cam, flex fuel sensor, meth injection. 820rwhp e85.
CJ27 is offline   Reply With Quote
Old 04-30-2021, 03:21 PM   #8
Bigtime53
Bigtime53's Avatar
Drives: 2013 ZL1
I hope the OP lets us know what was wrong and the fix he did to correct this.
Bigtime53 is online now   Reply With Quote
5thgeneration, cam, misfiring, zl1
