Old 04-27-2021, 07:59 PM   #1
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
id1300x injector help (hp tuners)
I just installed some id1300x injectors. I have scaled all the tables appropriately but I can't get the car to idle. The car starts, runs for a second or two then dies. Does anyone have a tune file with ID1300x injectors they'd be willing to send to me so I can compare mine. I must be missing a table somewhere.
Thanks in advance.
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
BigMatt is offline   Reply With Quote
Old 04-28-2021, 07:23 PM   #2
Tommy434
Tommy434's Avatar
Drives: 2014 SS 2010 SS 93 Camaro z28
I had the exact same problem with my 1700’s pcm of NC fixed mine 300.00 for a tune great people to deal with. I changed every scale I could find nothing worked
Tommy434 is offline   Reply With Quote
Old 04-28-2021, 10:56 PM   #3
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Double stoich, half IFR, half IVT. Done! No other tables need to be scaled.
I know this is covered on your hpt post, but thought I'd add it here as well for anyone who comes across it.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // BMR MM // BC Forged KL13
Mods being installed-
oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc.
RobZL1 is offline   Reply With Quote
Old 05-06-2021, 09:46 AM   #4
eLeSthree
Drives: 2011 Camaro SS 6sp
Make sure the table you are pasting data into, has the same UNIT measurement on the column and row axis as the ID1300 spread sheet.
You cant take data from a PSI sheet and paste it into a field using KPA.
You follow?
Then do what Rob said above. It should fire right up and run pretty well.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
