Old 04-27-2021, 11:23 PM   #1
Alex_Bumblebee
Alex_Bumblebee's Avatar
Drives: Chevrolet Camaro
CODE P0307
I intalled my headers and I have had them on with no tune for about 5 months I am now going to get a tune. Before the tune I went to see all the codes and I got P0307 which is my 7th cylinder misfiring any clue on how to fix the car is basically new has 28k miles and is 2012.
Alex_Bumblebee is offline   Reply With Quote
Old 04-28-2021, 12:28 AM   #2
d kings z28
Drives: 2014 white z28
New coil ??
DGK’s Z’s
d kings z28 is offline   Reply With Quote
Old 04-28-2021, 12:28 AM   #3
radar1972
Drives: 2012 IOM SS/RS
Since you’ve been in there installing headers, first thing I’d check is the spark plug wires to make sure they’re all seated properly.
radar1972 is offline   Reply With Quote
Old 04-28-2021, 04:31 AM   #4
SS Blinder
SS Blinder's Avatar
Drives: 2011 SS (Sparrow Spearer???)
so have you been running with a flashing check engine light all this time or did it just come in? a misfire condition makes the check engine flash. also, since you installed headers, check to see if your plugs are not cracked
Black magic woman, don't turn your back on me baby!
SS Blinder is offline   Reply With Quote
Old 04-28-2021, 02:05 PM   #5
Alex_Bumblebee
I have been running a check engine this whole time.
Old 04-28-2021, 02:37 PM   #6
DB Cooper
DB Cooper's Avatar
Drives: 2010SS
I'll register my guess... #7 plug wire melted and arcing to the header.
2010SS 6 speed - Hennessey HPE650 Serial #14
DB Cooper is offline   Reply With Quote
Old 04-28-2021, 03:11 PM   #7
Tarendor
Tarendor's Avatar
Drives: 2012 camaro 2ss rs L99
That's where my money is too.
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
Tarendor is offline   Reply With Quote
