Old 04-28-2021, 11:18 AM   #1
AG1LE
AG1LE's Avatar
Drives: '14 1LE
Spindle air duct adapters for brake cooling
I've seen a couple of forum users mention these, but haven't found details on customizing these for a reliable 5th gen brake cooling setup suitable for track use. I'm looking for a good alternative to the Quantum kit.
Anyone?
https://www.summitracing.com/parts/aaf-all42116
AG1LE is offline   Reply With Quote
Old 04-28-2021, 11:29 AM   #2
Crash76
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500
Ive been thinking about trying to 3d print a replacement for the metallic cover that has a spot for a hose. Another probably easier option would be to have a hole cut on the gm part and weld a adapter for ducting into it.
Crash76 is offline   Reply With Quote
Old 04-28-2021, 12:36 PM   #3
AG1LE
AG1LE's Avatar
Drives: '14 1LE
Interesting ideas - please keep us updated!
Old 04-28-2021, 02:32 PM   #4
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
You could find a set of Z28 ducts and Gen6 deflectors there’s article out there that say this actually better setup than a hose an spindle adapters.
Orange Krush II
Old 04-28-2021, 03:08 PM   #5
AG1LE
AG1LE's Avatar
Drives: '14 1LE
I have both (not yet installed). I would be interested to see that article to understand what is "better" about it. Seems like focusing air flow directly to the rotors would be optimal. I had planned to use an adapter to directly connect the Z/28 duct to a flexible duct hose at the wheel well...if I can find a spindle adapter.
I also have a set of 6th gen arms I was considering installing (which would obviously work well with the deflectors), but didn't get that far and am on the fence about using it due to the impact on alignment.
Old 04-28-2021, 10:42 PM   #6
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
There is other articles out there but I can’t find the one I’m looking for but this is a good start.
https://www.essexparts.com/news-blog...n-my-track-car
https://vorshlag-store.com/products/...-deflector-kit
Orange Krush II
