Old 04-29-2021, 10:33 AM   #1
kevint
Drives: 2013 1SS
Leveling springs for the rear
I did a search but could not find a vendor that offered coils to level the car. I like the overall ride height of the car, so I'm not looking to drop the whole car, just drop the rear a bit--about 1/2 inch--to level it. Any ideas? 2013 SS.
kevint is offline   Reply With Quote
Old 04-29-2021, 12:55 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
Don't believe any manufacturers make such springs. If you want to keep the factory ride height while lowering/leveling the rear you'll have to go with coilovers, although a bit pricey for such a purpose.
If you decide to lower the whole car, some manufacturers make different-length spring sets such as Eibach (1.0" front, 1.3" rear) while others such as BMR have a few springs/heights to choose from, and you can mix and match (although perhaps not necessarily the intended use for such springs - the spring rates might not necessarily be compatible with each other, but then again if it's just for street use you'd probably be fine).
KillboyPowerhead is offline   Reply With Quote
Old 04-29-2021, 02:30 PM   #3
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
ZL1 springs drop the rear about half an inch.
Old 05-03-2021, 01:41 PM   #4
kevint
Drives: 2013 1SS
Thanks for the replies, everyone. It turns out that a full tank of gas drops the rear down to the appropriate height.
ZL1 springs would be a good option but it looks like they're a bit softer, so I'd need a stiffer sway bar for cornering. Not the worst thing in the world, but I can't let the snowball grow until after my wedding later this year.
Old 05-03-2021, 02:53 PM   #5
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
So be careful mixing ZL1 springs they are linear an SS are progressive or vice versa , also the shocks might not play well either due to valving mag ride vs normal shock. I asked these questions and got answers Justice Pete plus I would talk with him an CamaroFest.
Orange Krush II
Old 05-03-2021, 03:49 PM   #6
CamaroCracka
Where did you hear that ZL1s are linear Blue? I got a set back in 2014 and found an article on the ZL1 in Super Chevy said they use a variable rate spring in the rear [70 N/mm (400#) to 45 N/mm (257#)] and 27 N/mm (154 lb) in the front.
Edit: Never mind, I noticed where you said or vice versa.
