#Camaro6
BeckyD @ James Martin Chevy
Old 04-29-2021, 11:48 AM   #1
Grumpy1
Grumpy1's Avatar
Drives: 2018 ZL1 Hyper Blue A10
Cooling
Guys with 700hp and up, what are you doing for cooling?
Shop was kicking around putting the weapon x exchangers on.....kind of pricey and the Maggie is pretty efficient keeping the temps low
Suggestions:
Grumpy1 is offline   Reply With Quote
Old 04-29-2021, 11:51 AM   #2
Z OH 6
Drives: 2021 Red Hot ZL1
Vengeance Racing installed AFCO heat exchangers on mine.
Z OH 6 is offline   Reply With Quote
Old 04-29-2021, 12:41 PM   #3
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Suggestions:
Im at 800, and i don't have any aftermarket heat exchangers. Just the maggie 2650. I don't track the car though.
I don't have any heat issues though running it hard with coolant or oil temps. MAT temps stay around 105-120 in 90F weather while moving (depending on speed)
928rwhp - 93 | 1040rwhp/898rwrq - E65 SAE
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Camaro1973 is offline   Reply With Quote
Old 04-29-2021, 01:26 PM   #4
Grumpy1
Grumpy1's Avatar
I was thinking I could get away from changing anything. Mine will strictly be a street car with the occasional trip to the drag strip.
I was looking at you signature, getting those numbers what did you do with fuel besides the bigger cam?
Old 04-29-2021, 02:54 PM   #5
LAPPEDbyZL1
Drives: 2018 Camaro zl1 1le
I replaced my radiator/ heat Exchanger from Dewitt radiator. They are the manufacturers for weapon X radiators and the radiators that go on the Camaro gt4.r cars
LAPPEDbyZL1 is offline   Reply With Quote
Old 04-29-2021, 03:37 PM   #6
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Nothing was done to the low side. High side just the cam.
Old 04-29-2021, 04:26 PM   #7
Jason18ZL1LE
Drives: 2018 ZL1 1LE
See my sig for power levels.
C&R Racing Radiator
Prospeed Intercooler with C&R Core
160 LS3 Style Thermostat and housing
Cordes Big3 1Gal Reservoir
Parts I have that I still need to install include Air to Oil cooler to ditch the lack luster Water to Oil cooler. C&R Racing makes a cooler core that replaces the aux cooler for the intercooler if you are using their giant intercooler (which I am).
I road race my car, and I make 900hp at the crank. The oil will see 275F and because of the super high oil temps the coolant with all these mods will still see 230F.
C&R Claims a 50F reduction in oil temps and a huge reduction of coolant temps as well with the removal of that heat source from the coolant loop.
I will report back how well it works.
2018 ZL1 1LE - Summit White
529whp Baseline / 760whp 762tq
ARH Ceramic Coated LTH 1 7/8" \ ATI 15% Lower \ RotoFab Big Gulp \ Katech 103mm TB \ Ported Blower \ DSX Fuel System \ Flex Fuel E85 \ Custom Cam \ Dual Springs \ Corsa Exhaust \ Prospeed Heat Exchanger \ Cordes Big3\ C&R Racing Radiator \ LS3 Stat housing \ 160* Thermostat \ NX Lid
Jason18ZL1LE is offline   Reply With Quote
Old 04-29-2021, 07:54 PM   #8
Sickspeedkuwait
Sickspeedkuwait's Avatar
Drives: '17 ZL1 M6
I am running Weapon X triple heat exchangers
Top run - 2.3 upper, ARH 1 7/8 LT's, Rotofab intake, 180F thermostat
Bottom run - Added Weapon X HE's, Kong ported blower, 103TB (gained 2 lb's of boost)
Looks like it's running cooler even with the added boost
Sickspeedkuwait is offline   Reply With Quote
Old 04-29-2021, 08:34 PM   #9
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
You are missing the actual temp that matters, MAT, IAT2 is invalid for this car. Guarantee you are 120-140+°F MAT.
2017 Camaro ZL1 Coupe M6 (847whp Dynojet on 93)
LiqTenExp is offline   Reply With Quote
Old 04-29-2021, 08:47 PM   #10
Sickspeedkuwait
Drives: '17 ZL1 M6
Isn't MAT a caculated value?
I wanted to compare the direct effect on IAT2.. I do know that timing tables take MAT values
Old 04-29-2021, 08:57 PM   #11
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
MAT is what drives IAT Advance aka what will pull timing.
IAT2 is calculated based on ECT.
Old 04-29-2021, 09:00 PM   #12
Sickspeedkuwait
Drives: '17 ZL1 M6
Old 04-29-2021, 09:09 PM   #13
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
If you unplug MAF you will lose IAT1/IAT2 but MAT will still read. In stock blowers MAT is from the TMAP sensor on the back of the blower. Most aftermarket blowers breakout and relocate the temp sensor from the TMAP out of that location for less heat soak. For example my 2300 MAT sensor is in cylinder #2.
Old 04-29-2021, 11:16 PM   #14
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
This is correct. IAT2 is a useless reading. It's usually roughly 10 degrees F above IAT1 which is your actual intake air temp. The proper pid is "Manifold Air Temp". This is the important one. With intake air temps like yours, with the stock blower its probably around 140F.
See my SS of some of what i log.
