Old 04-30-2021, 09:09 AM   #1
KillerBomb24
KillerBomb24's Avatar
Drives: 2012 Camaro 1LS
LFX engine gas octane
I have had a 2012 v6 camaro for the past year and have been putting 93 in it. The reason being is that the original owner money shifted the original engine and replaced it with another lfx engine. He told me to put 93 in it but I see no reason to do so. Would putting basic 87 cause any problems? I have put 87 in it once and didn't notice and difference in performance or sound but I just don't want to cause any damage.
KillerBomb24 is offline   Reply With Quote
Old 04-30-2021, 09:24 AM   #2
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
it requires 87 octane no need to run more than 87. Even the SS's have a low octane table set up so it will run on 87. Top tier fuel is recommended though, has detergents to help keep from carbon buildup.
Greenhornet2 is offline   Reply With Quote
Old 04-30-2021, 09:58 AM   #3
redcoats1976
i have used 87 and 89 in my LFX,and there is no real difference.i just have a hard time putting lawn mower gas into my car so i prefer the 89.only reason you would need 93 is if the car had been custom tuned to run on higher octane.
Old 04-30-2021, 10:26 AM   #4
Greenhornet2
Running Higher octane than is required is actually detrimental to an engine. Higher octane resists combustion. When the tuning is set up to run 87, running higher octane will lead to a less complete burn and more carbon deposits and actually less power.
Old 04-30-2021, 10:49 AM   #5
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
There's tons of threads and topics on this and you will get both sides of the spectrum on this.
When I owned my v6 and data-logged, the low octane tables were awful. They pulled so much timing and used knock sensors like crazy. The car ran much better on 93 octane.
Eventhough this is "just a v6" it's also a high-compression, direct-injected, DOHC engine with a lot of sophistication. The LS3/L99 is old technology, so you can't really use the v6 vs v8 debate on these two engines in my opinion.
I recommend high octane for the v6.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 04-30-2021, 12:55 PM   #6
KillerBomb24
I do believe the car was tuned before I had it. Is there any way to find out without going to a tuner?
Old 04-30-2021, 01:31 PM   #7
KenKat
KenKat's Avatar
Drives: 2014 2LT RS Summit White
I ran 93 in mine for a few months and didn’t see any performance or fuel economy differences although I also know others have had different results. I just run 87 nowadays.
KenKat is offline   Reply With Quote
Old 04-30-2021, 02:21 PM   #8
redcoats1976
mines bone stock,but some of the other people here might know how to tell...i see you also live in hot and humid florida,thats one reason i like to use 89 instead of 87 octane.
Old 04-30-2021, 02:56 PM   #9
spyderbuddy
spyderbuddy's Avatar
dead horse
2024 Camaro/Panther Emblem,Hot Wheels Emblems, Hot Wheels Door Sills and Floor Mats, Morimoto Fog Lights, PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting & My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller & Paddle Shifter Heritage Grill, Manual Shifter Boot, CNC Throttle Body, Trifecta Tune, Trunk Black out and Side Grills,
Old 04-30-2021, 05:59 PM   #10
redcoats1976
but...what do you feed a dead horse?
Old 04-30-2021, 07:35 PM   #11
spyderbuddy
mine gets premium 93 feed
Old 05-01-2021, 02:04 AM   #12
AlanRubin
Banned
Drives: 2010 LS
Run the higher octane when ambient temperatures are above 60 degrees.
If you feel the timing being pulled in hot weather, use higher octane. I can tell when
the timing is being backed off. When I change to higher octane, that doesn't happen.
I can feel the timing pulls in 2nd gear.
Winter, I run 87 or 88, but when the summer comes around, you need the higher
octane level to prevent timing pulls.
Believe it or don't, but I can tell the difference. I know how to make my engine
knock and ping while going up a hill, in "M" 5th. There is a specific hill I run up,
and press the pedal almost all the way to the floor, and when it hits a certain
point I can hear the clattering. When I run with 91 or higher octane, it doesn't
happen. Running higher octane also increases fuel mileage, from 15 gallons to
14.5, and with the intake now ~13.5 per 380 miles. I run the same 380 miles 3-4
days a week, so I test all the fuels, in all the temperatures, so I got it down pat.
I fill the tank with 88 till the pump shuts off, then I squeeze 2 more gallons of E85
on top if it. Did the round trip back to the same gas station, it took ~13.5 gallons.
AlanRubin is offline   Reply With Quote
Old 05-01-2021, 02:24 AM   #13
PaulsSS
Drives: 15SS Camaro
My v6 runs terrible on 87 but of course it does because it has a premium gas tune in it. Like Chibi mentions up above the low octane tables are horrible. If I put regular gas in the car runs so bad you never put it in again.
My Subaru calls for regular but there are times I can hear it pinging and pulling timing. you can feel the reduced power. The Camaro on the other hand just flat out won't go it pulls that much timing on 87.
PaulsSS is offline   Reply With Quote
Old 05-01-2021, 02:25 PM   #14
xstuntman
Drives: 2012 Victory Red LFX
Agreed.
Motors around 11.5:1 compression and detonation is the enemy. Will it run on 87? Sure. It would run on retreads and dino oil too. Never saw the point of being cheap on fuel, oil or filters myself.
'18 SS wheels, Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, painted red rotors and calipers, 1/4 window American Flags, splash guards, AEM dry panel air filter.
xstuntman is offline   Reply With Quote
