![]() Drives: 2015 camaro ls Join Date: Apr 2021
Raise front seat for better visibility
The following steps show how one can raise the front passenger seat on a 2015 Camaro for better visibility.
1/ Unbolt the two star bolts that secure the seat sliding rails to the car frame with a T50 bit. 2/ Once the bolts are unscrewed, slightly slide the seat backward to unhook the rails from the car floor 3/ Use a flat screw driver to push the locking clip side way to unlock the electrical connector. 4/ Protect your door and door frame with blankets to prevent scratching the paint and lift the seat out of the car. 5/ Unbolt 6 bolts that secure the seat to the sliding rails 6/ Cut 4 pieces of 2"x2"x0.065" 3" length tubing and drill holes through them using a 5/16 drill bit as straight as possible 7/ Bolt the seat frame on to the sliding rails using grade 8 or better 3" length bolts and nuts with plastic locking insert 8/ Put the seat back in the reverse order as it was taken out of the car |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: ABM #93 Join Date: Oct 2018
I hit my head on the roof as it is and I’m not the tallest guy in the world, not sure how well this would really work with headroom.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
#3 | |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
https://youtu.be/sT_78skgs9k?t=20 raise da roof Op thanks for posting this info I'm sure it will help someone who needs this, I noted you said passenger seat which might help make some significant others accept the car better. I'm sure there are a few who would like this for the driver side too. With limited sunroof headroom I can't, but did notice the problem yesterday again as I lean way forward trying to park the car in the small garage without hitting that blindspot right front fender on the wall. |
![]() Drives: 2014 2LT RS Summit White Join Date: Apr 2017
Lol, I have my seat all the way lowered; I can tell it’s time for a haircut when I can feel my hair brushing up against the headliner!
Amen to that, It’s hard to wear a hat because the brim is always bouncing off the roof as I move my head around. I’ve never had the visibility issues some people complain about though, if I did I’d probably trying to figure something else out.
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: LT W/2LT,blue metallic Join Date: Jul 2016
im guessing some camaros dont come with the power seat to rauie and lower the whole seat?
#7 |
I'm fine in the driver seat but my wife would love the passenger seat raised a few inches in my 2011, which does not have that adjustment for the passenger.
#8 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
What's a passenger seat?
#9 |
you know...so you can pick up girls.
#10 |
#11 |
When yo girl is shorter than 5.4, you have to do anything to make her happy. Of course, when she's happy, you'll be happy too... trust me.
#12 | |
Not an issue on the driver side
I'm 5.3 and I can see fine on the driver seat. But the passenger seat is too low and the passenger seat can't be raised higher like the driver seat. This is why I have to do it cuz my wife said it's too low. |
#13 |
#14 |
| Tags |
| 2015 camaro, front seat, raise front seat |
