Old 05-03-2021, 03:03 PM   #1
BlownHennessey
Drives: 2010 Camaro HPE650
2010 Camaro....3800 miles.......noisy front suspension
I have a 2020 SS/RS. Has been lowered since new and rarely driven. 3800 miles in 11 years. Always parked in climate controlled garage. This year after taking it out, I am noticing a very harsh front end with some clunks going over bumps. What do you thing has gone bad or dried up? They are factory struts on BMR springs. Tires are at 33psi.
BlownHennessey is offline   Reply With Quote
Old 05-03-2021, 03:51 PM   #2
gtstorey
My first guess would be sway bar end links, but I don't know how likely that is on a 3800 mile car. Might be struts.
Old 05-03-2021, 09:50 PM   #3
kevint
Drives: 2013 1SS
The front ends of these things are noisy--there are a lot of posts on here about this. My impression is the struts "float," in that they're not rigidly mounted to the strut towers, but held in place by the weight of the car. A big conical washer stops the strut from falling through the tower when the car is lifted. When the spring forces the system to extend as it recovers from a bump, it may extend against the strut tower, hence, the noise.
kevint is offline   Reply With Quote
Old 05-09-2021, 07:20 PM   #4
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
Sway bar bushings, the ones under the clamps that bolt the sway bar to the subframe, front and back. Lube with silicone grease used on poly bushings. They tend to make a popping/knocking noise.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter, SS brake lines ZLI calipers, rotors/pads BMR Trailing & Toe Arms, rear cradle/diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers, HF cats, GMPP axle back, Elite Eng Catch Can, Black ZL1 20x10 & 2011 whls 285/35/20 & 305/35/20 General G-Max RS, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console, hand brake lever, Grant steering whl.
flht99b is offline   Reply With Quote
