Old 05-04-2021, 01:25 PM   #1
chuck9987
Drives: 2013 Camaro 1LT
Help finding a used rear differential for 2013 Camaro 1LT manual
My rear differential is cooked and I’m having a hard time finding a used one that will fit. I have a 2013 Camaro 1LT with a manual transmission. Part number on my rear is 22928326 218mm 3.27 LSD. I’ve found a few used on eBay but they came out of automatic cars so even tho it’s the same part number I don’t think it will fit. Anyone know if they would work?
Any info on finding used rear diff will be appreciated.
chuck9987 is offline   Reply With Quote
Old 05-04-2021, 02:15 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
Someone correct me if I'm wrong, but the auto diff is different and you would need the rear half of driveshaft and back (all the way to hubs) to make it work, plus you'd lose your limited slip. Not sure where to find a diff - I don't believe you can even buy them new anymore - I guess GM thinks differentials don't fail? I was hoping to swap to a 1LE diff for the 3.91 gears but I guess I'll have to wait until a used one pops up, and then pay 10x what it's worth for shipping...
KillboyPowerhead is offline   Reply With Quote
Old 05-05-2021, 11:56 AM   #3
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
All the 218mm diffs use the same housing. Only the Z28 uses a different carrier, but even then the spline count is the same. If you have a manual V6, the auto SS diff should work. Hell G8 guys replace their 192mm diffs all the time with them.
Old 05-05-2021, 12:15 PM   #4
gtstorey
yes part # 22928326 is the same as auto ss
2013 1lt, manual tranmission, rear differential
