Old 05-04-2021, 09:39 PM   #1
antocamaro
Drives: Chevrolet camaro ss 2011 ,
which oil should I put in my tr 6060? dexron 3 atf?
what is the best oil to put in my tr 6060 on my ss 2011
antocamaro is offline   Reply With Quote
Old 05-04-2021, 09:47 PM   #2
Vegas Bound
Drives: 2013 Sparkly Red One
What does the owner's manual say?
Vegas Bound is offline   Reply With Quote
Old 05-04-2021, 10:06 PM   #3
antocamaro
The owner's manual only say GM Part No. 88861800. LI did some research and found this "Dexron III is being phased out as a product name. It is being renamed Manual Transmission Fluid and carries p/n 88861800 U.S. (88861801 Canada). If fluid p/n 88861800 U.S. (88861801 Canada) is not yet available when servicing a manual transmission or transfer case, Dexron III can be used in its place." Now i was wondering if it was the dexron 3 that you were using and if it had a particular brand i saw that a lot was using redline d4 atf which i believe i am using for the moment
Old 05-05-2021, 01:15 AM   #4
Avenging Orange
Avenging Orange's Avatar
Most all your brand name lubricants that meet the requirements will all work fine with no dire affects. Even folks such as myself, who uses non synthetic fluids, have found that the car will not implode because I do.
Take care of your automobile and perform the proper maintenance when required, and it will last a long time.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 05-05-2021, 03:32 AM   #5
George-CZ
George-CZ's Avatar
Drives: 2010 2SS LS3 and 1978 STROKER 383
Change to the Red Line D4 ATF.
When the oil in the transmission was cold, the shifting second gear was wrong. After the oil was operating temperatures, the problem disappeared.
I attributed it to thick oil, which probably gets badly into moving parts with minimal tolerance.
After changing to the Red Line, the problem improved significantly.
So if ATF, for me only Red Line D4 (maybe Royal Purple).
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune.
George-CZ is offline   Reply With Quote
Old 05-05-2021, 07:28 AM   #6
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
I used redlind as well. Works well helped the notchy issue when cold
Greenhornet2 is offline   Reply With Quote
Old 05-05-2021, 09:03 AM   #7
ADVMax
Sporting Foole
ADVMax's Avatar
Drives: 2010 Camaro SS
Redline D4 recently for me! Trans hasn't fallen out yet?
ADVMax is offline   Reply With Quote
Old 05-05-2021, 12:22 PM   #8
4.0=SS
4.0=SS's Avatar
Drives: 2010 Camaro 2SS RS IOM/Blk, Borla
I used redline d4 but my 2-3 shift is "notchy" any ideas?
4.0=SS is offline   Reply With Quote
Old 05-05-2021, 01:09 PM   #9
antocamaro
My dealer uses the acdelco 88861800 oil with the exact part number from the owner's manual has anyone tried this oil?
Old 05-05-2021, 01:25 PM   #10
George-CZ
George-CZ's Avatar
I'm not local. I don't know what "notchy" means
Old 05-06-2021, 09:54 AM   #11
ADVMax
Sporting Foole
ADVMax's Avatar
me too until it warms up.
they all do that
